Ctrl + L not selecting al faces of an object #97884
2 Participants
Reference: blender/blender#97884
Operating system: WIndows 10
Graphics card: GTX 1080 Ti
Broken: (3.1.2)
Selecting a face and pressing Ctrl+L is not selecting all faces of the object. Was working fine yesterday, and still works on the default cube project, but will not work on any of my own projects. Selecting a face and pressing Ctrl+L only brings up the "Selected Link All" menu, of which none of the options do anything.
Added subscriber: @mrcap21
Added subscriber: @rjg
CTRL + L in edit mode, which is equivalent to Select > Select Linked > Linked, will select connected geometry (see Blender's manual for details). If the geometry in your own projects is not connected, e.g. due to non-manifold geometry, disconnected faces, ... then it will not select the entire mesh, only those parts that are connected.
You can check if you have non-manifold geometry by deselecting everything in edit mode and then applying Select > Select All by Trait > Non Manifold. Does this identify issues in the geometry of your own project?
Thanks for the response, but my "Select All by Trait" menu doesn't seem to have a "Non Manifold" option. I checked the others to be sure but I don't see it anywhere. And if that is the case, is there any way to connect them? There are a lot of rounded edges on this model so it would save me a bunch of time.
This comment was removed by @mrcap21
Alternatively, you can enable the 3D-Print Toolbox add-on in Edit > Preferences > Add-ons. Once enabled, you can use click on Check All in the sidebar for a series of tests.
@mrcap21 Could you check whether this issue is caused by disconnected geometry?
