Update animation operators for previously hidden redo panel contents #98195
Open
opened 2022-05-17 14:38:36 +02:00 by RedMser · 3 comments
Contributor
With the changes in D14960, many operators that had previously hidden options are showing their redo panel.
This applies to the timeline editor, dopesheet (all modes) and NLA editor.
I tested all operators in each editor to find out which ones need changes. The following list is complete, meaning that any operator that is not listed here works as expected when tweaked:
Dopesheet
    • Transform
    • Hide W axis
      • Not sure how to do this for transform.transform with TIME_TRANSLATE
    • Box Select
    • Hide redo panel (it never shows in 3d view)
    • select_column
    • Hide mode selector (the modes are very distinct from each other, and don't make sense to be changed by the user)
    • leftright
    • Hide the "Check if Select Left or Right" mode
      • Does not seem like you can hide enum entries, so this may have to be split into a separate property
Markers
    • Holding select (rightclick)
    • Hide redo panel
    • Move
    • Hide tweak checkbox
    • Select before/after
    • Capitalize parameter names
    • Box Select (see Dopesheet)
NLA Editor
    • Duplicate
    • D15086 fixed the issues related to the duplicate operator
    • Push Down Action
    • Hide redo panel (seems to be an internal property not worth changing)
    • Transform (see Dopesheet)
    • Additionally, the Proportional Editing property can not be toggled (probably since the NLA editor does not have this option at all), so the checkbox should be hidden
    • leftright (see Dopesheet)
Graph Editor
While not affected by the above patch, it's still worth touching up, since the original patch that added its redo panel D6286 did not change related operators either.
    • Box Select
    • While we should hide redo panel for consistency, the "Select Curves" option may be interesting to toggle? But at the same time, it currently does not update, so needs to be fixed.
    • select_column (see Dopesheet)
A lot of operators would benefit from functional changes, now that the user can adjust their parameters not only through different menu items, but also by tweaking the settings in the redo panel.
This could be tracked as an additional to do task.
With the changes in [D14960](https://archive.blender.org/developer/D14960), many operators that had previously hidden options are showing their redo panel. This applies to the timeline editor, dopesheet (all modes) and NLA editor. I tested all operators in each editor to find out which ones need changes. The following list is complete, meaning that any operator that is not listed here works as expected when tweaked: # Dopesheet - - [ ] Transform - Hide W axis - Not sure how to do this for `transform.transform` with `TIME_TRANSLATE` - - [x] Box Select - Hide redo panel (it never shows in 3d view) - - [x] `select_column` - Hide mode selector (the modes are very distinct from each other, and don't make sense to be changed by the user) - - [ ] `leftright` - Hide the "Check if Select Left or Right" mode - Does not seem like you can hide enum entries, so this may have to be split into a separate property # Markers - - [x] Holding select (rightclick) - Hide redo panel - - [x] Move - Hide tweak checkbox - - [x] Select before/after - Capitalize parameter names - - [x] Box Select (see Dopesheet) # NLA Editor - - [x] Duplicate - [D15086](https://archive.blender.org/developer/D15086) fixed the issues related to the duplicate operator - - [x] Push Down Action - Hide redo panel (seems to be an internal property not worth changing) - - [ ] Transform (see Dopesheet) - Additionally, the Proportional Editing property can not be toggled (probably since the NLA editor does not have this option at all), so the checkbox should be hidden - - [x] Box Select (see Dopesheet) - - [ ] `leftright` (see Dopesheet) # Graph Editor While not affected by the above patch, it's still worth touching up, since the original patch that added its redo panel [D6286](https://archive.blender.org/developer/D6286) did not change related operators either. - - [x] Box Select - While we should hide redo panel for consistency, the "Select Curves" option may be interesting to toggle? But at the same time, it currently does not update, so needs to be fixed. - - [x] `select_column` (see Dopesheet) - - [ ] `leftright` (see Dopesheet) --- A lot of operators would benefit from functional changes, now that the user can adjust their parameters not only through different menu items, but also by tweaking the settings in the redo panel. This could be tracked as an additional to do task.
RedMser self-assigned this 2022-05-17 14:38:36 +02:00
Author
Contributor
Author
Contributor
Added subscriber: @RedMser
This issue was referenced by 3132d2751e
This issue was referenced by 3132d2751e61961d46a2aaf168893a6ba7d03a0b
Philipp Oeser removed the
label 2023-02-09 14:35:05 +01:00
2 Participants
Reference: blender/blender#98195
