Bloated mesh data example (multires CD_MDISPS hanging around without a multires modifier) #98249
2 Participants
Reference: blender/blender#98249
Graphics card: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 3.2.0 Beta, branch: master, commit date: 2022-05-16 16:16, hash:
a2dacefb46
Worked: Unknown
Mesh data seems bloated when saving a blend file. I have an example file attached with one mesh object with 400 faces that is around 6mb when saved to disk. This is a super simple example.
I noticed inconsistencies when saving out lots of different character mesh combinations with compression, some files on disk were ~700kb and some as high as ~48,000kb for essentially the same face counts.
I did some tests (with the attached scenes), by exporting the mesh as an OBJ and bringing it back in again and saving as a new file. This saves around 5mb.
I can't see the difference between the two the meshes, so I can't account for the 5mb of bloat. Is this a Bug? Is there a work around?
For now I think I'll have to write a tool to 'clean' the meshes by exporting and re-importing them.
See the attached files; bloated mesh.blend, mesh.obj, imported obj mesh.blend.
Not much to reproduce, I guess it is a case of why is the 'bloated mesh.blend' file so large.
Much appreciated, Mal
example_files.zip
Added subscriber: @reed2000
Added subscriber: @lichtwerk
Hm, can confirm, will check
Hm, there is an unnamed customdata layer on the loops (seems to be multires data).
If I exclude this from file writing, the filesize goes down again:
P2962: T98249_snippet
Not sure how that ended up there (dont think this was created from python? -- those customdata layers usually have a name enforced...)
@reed2000: any idea how this happened? got a way to reproduce from scratch? Is this an old file?
EDIT: there is a way to get rid of the multires data again, just add a new multires modifier and remove it again
Changed status from 'Confirmed' to: 'Needs User Info'
So we will need to find a way to reproduce this borked multires data hanging around
Bloated mesh data exampleto Bloated mesh data example (multires CD_MDISPS hanging around without a multires modifier)Ah, we had this before...
So, it is a duplicate of #88144 (Multires modifier data (CD_MDISPS) can remain on a (once shared) mesh, bloats filesize, adding a new multires modifer will already have its levels then), will merge reports...
Closed as duplicate of #88144
Hi Guys,
Multires is part of my workflow, I have a mesh I setup and UV'd, then add a multires and sculpt. Sometimes the multires is applied at a high level to capture the sculpt data then a new one added and unsubdivided. I'm fairly lose with the application of this method of working.
Whatever data is left around, could we not have an actionable step to remove that data once all modifiers are removed and the artists wants a clean mesh for export?
The data is usually removed alongside the modifier.
But there is this special case when you switch an object's mesh to a mesh that has a multires modifier.
In this case you end up with the data on the mesh (even though you dont even have a modifier on the object).
That is the limitation of the current design, just keep that in mind.
Does that answer your question?
Yeah it does, thank you, that is really useful to know how to fix it.
Just wondering if the mesh cleanup tools or similar should offer a fix for example, as it's easy to get a twist.
Cheers.
For anyone else who finds themselves here:
