Regression: Calling save on image fails due to file path options not being correctly applied #98305
6 Participants
Reference: blender/blender#98305
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.59
Broken:
dfb8c90324
29a3f43da5
Worked:
29a3f43da5
Setting
filepath_raw
on anbpy.types.Image
object and then callingsave()
results in the error:This issue affects the glTF exporter and third-party add-ons such as Blender2MSFS2.
Added subscriber: @lionheart001
Added subscriber: @rjg
Is it correct that you are using the Blender2MSFS2
third-party add-on from this repository https://github.com/tml1024/Blender2MSFS2 ?
Added subscriber: @scurest
Note that the same thing happened in CI for the glTF addon repo. https://github.com/KhronosGroup/glTF-Blender-IO/pull/1646#issuecomment-1132006357
Added subscriber: @JulienDuroure
@scurest Thank you for noticing. Seems like this could be an issue in Blender and needs further investigations, if this occasionally fails with the official glTF add-on as well.
@rjg I can confirm that exporting this file as glTF separated is ko since a few days (last ok CI was 5 days ago)
bea4c6d2c9/tests/scenes/01_principled_material.blend
Yes, that is the one. A stable compiler. There are two out there, this one runs best. Version 42.10 by RonH
We export these 'seperated' also.
Bill
@JulienDuroure Are there any particular steps necessary, or does just an export of the project as-is to
.glb
fail? Does this fail consistently or occasionally?Current master (
dfb8c90324c018068f12ca41543c3c311dff6d21
) seems to be working fine on my system with the provided file.Edit: I have just noticed that the textures are not packed. I will test this again tomorrow with the textures, just in case that makes any difference.
Seems to break without any condition on github CI.
Don't have a computer to check right now, but did you change export format to glTF separated, instead of glb ?
First test with glTF Separate seems to be working fine, but I will check again tomorrow with the images. Just so that we are not looking at different commits, could you please post one of the affected commit hashes that fails in your CI?
I can repro with current alpha (blender-3.3.0-alpha+master.dfb8c90324c0-linux.x86_64-release). Binary/Separate etc. doesn't make a difference.
Reduced test case:
Stick it in a text editor and run it. Fails with current alpha. Works on 3.1 & blender-3.3.0-alpha+master.08a39d32a988.
@scurest I can reproduce the issue with your script (presumably the issue was not triggered with the exporter due to the missing images). I will update the ticket description tomorrow so that it is fully triaged and confirmed.
Possibly related to
29a3f43da5
.Cannot Export glTF-2 files, getting errorto Regression: Calling save on image fails due to file path options not being correctly appliedChanged status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @brecht
@brecht This is likely a ticket for you.
@scurest Thank you for looking into this.
This issue was referenced by
eba6900b08
Just to let you know, I did test Build 3.3 May 23rd and May 24th (today) with exporting glTF-2 (MSFS format) separated. Build May 24th got quite a ways along before it crashed. Much better then the instant black crash screen. Must be close.
Bill
LHC
Hello,
I confirm that there is no more issue on glTF exporter!
Thanks
Just ran Blender 3.3 May 25th Build. I was able to export first half of the scene I am working on, but the interior section of the scene still fails. But... It is attempting to build it instead of just throwing out the error notice. It runs for several long seconds until the error pops up. So close...
Again, the file exports fine in Blender 3.1 and 3.2.
Error notice attached..
The actual error is scrolled out of view, it would be at the very bottom. It should be easier to copy the text from the console window (Window > Toggle System Console in Blender).
Removed subscriber: @scurest
Roger that, Brecht.
Got it.
Hello Team Blender,
I just wanted to report that I just tested Blender 3.3 Alpha May 26th Build with exporting glTF-2 in MSFS exporter by RonH, and..... IT WORKED!!!!!!!!!!!!!!!!!!!!!!!!!
Thank you Team Blender. I can once again begin testing Alpha daily. Very grateful for your help on this. God bless you.
Bill
LHC
