Mantaflow not caching if path contains characters with accent #98467
Reference: blender/blender#98467
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
If the cache folder path for Manta FLow contains "french" accent character, no sim data is computed.
Move forward to the fluid sim... No simulation data create
To fix it :
It works
If cache folder is relative to .blend file or absolute, it doesn't create data if the path contains any character with accent.
Thank you for the great job you are doing
Have a nice day
Didier
Added subscriber: @MagicDid
Added subscriber: @iss
Can confirm, but since there is no active developer for mantaflow, will set as known issue
@MagicDid Can you check if this bug is still happening for you in the 3.3 daily build? I think it might have already been resolved there...
Hi,
I've downloaded the 3.3 daily build and tried to bake a Mantaflow simulation and it doesn't work if the path of the .blend file contains an accent. A single default cube and apply quick effet / smoke doesn't generate simulation data if the file is stored in
..../Données/MyProject/anyfile.blend
I just renamed it to
.../Data/MyProject/anyfile.blend
, reopened it and this time simulation data are generated.Tell me if you need any log/file/etc...
@MagicDid |I have created a C:\Données\test.blend . I added a Object > Quick Effects > Quick Smoke to the cube. The cache directory is relative to the blend file as indicated, and when I hit Bake All I can play the animation and see the simulation in Blender 3.3 alpha.
When I try that on Blender 3.2.1 I don't see any simulation. Are you certain it was the 3.3 build you used to test it? Or am I missing somethiing in my test?
Here is the test environment (see screenshot). The 3.3.0 alpha is from June 28th (this morning).
It seems you're doing the right test. Cannot understand what is the difference between the 2 environment. The only thing I have to change to make it work is the
Données
changed toData
.Have you tried both accent and space in the path ?
Hello,
I've downloaded the last Blender release from Git, rebuilt it and when I check the
MANTA_main.cpp
file, it seems that the modification detailed in https://developer.blender.org/D15301 are not included in this release.Didier
Hi again,
I've added some Log to understand what happens. Here are the Python command strings "tried" to be executed :
Indeed the "é" character is interpreted into something else between the GUI and the internal Manta wrapping implementation.
Hey @MagicDid , yeah the problem is that code doesn't actually fix the issue. I thought that was fixing the issue, but the problem is that it's already working for me in the latest release. So when I tested my changes I thought it was fixing the bug, but it wasn't actually doing anything different.
I tried to recreate this issue with a space in the filepath
C:\Données\Folder With Space
and it also works as expected for me on 3.3, but not on 3.2.1. I'm not really sure why we're seeing different results, maybe it's an issue with environments, but I'm not able to dig any further on it without being able to recreate it I'm afraid...Added subscriber: @SonnyCampbell_Unity
@MagicDid where did you add that logging and I can add it in the same place to see if I can spot any difference?
In file
C:\Projects\Blender\blender\intern\mantaflow\intern
In
runPythonString
method :I'm working on using the
BLI_get_short_name
function to solve this issue (at least on Windows platforms)Yeah I see the same in mine:
but my simulation runs when I play the animation
and my fluid cache has the data
I'm on Windows 10 too.
Hi,
I finally succeeded in understanding what happens in my case. The issue is due to the OpenVDB implementation at the end of the C++ => Python => C++ architecture of Mantaflow in Blender. Here is a sequence diagram of the successive calls leading to the erroneous interpretation of the path at the end.
During all the sequence the path is correctly interpreted as UTF-8 and finally in the OpenVDB implementation the path is interpreted as a basic string (ASCII) by use of std::ofstream with std::string instead of std::swstring. As this is in OpenVDB distribution, there is no chance this to be fixed.
To prove this, I changed the export format to "UNI cache" instead (which is not implemented the same way) and the simulation bake works and I can play it...
Now I know it I'll change my folder's name.
Thanks for your time
Question : how can I help by fixing some issues in Blender ? How to pick up issues ?
@MagicDid Thanks for detailed analysis.
In general, pick area you would like to work on and contact developers that maintain this area. They can probably provide you with easier tasks here on tracker so you can get familiar with development process. See https://wiki.blender.org/wiki/Modules
It's good idea to read through wiki and good starting point is https://wiki.blender.org/wiki/Developer_Intro/Overview
