Boolean with extruded single vert on mesh not working #98496
2 Participants
Reference: blender/blender#98496
Operating system: macOS-12.3.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Pro Apple 4.1 Metal - 76.3
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Worked: -
When I add a single vert and extrude and fill it to some geometry, for an boolean operation, to cut a slice in a uv sphere, it doesn't work. Its only diffrence that isn't working at all, on union it works fine, on intersect it sometimes works and when I use one of the standard meshes to cut it, it works fine. So only when extruding the single vert to a mesh this problem occurs.
Add UV Sphere; add single vert; extrude single vert 3 times to a square; fill in the start and end vert to connect them; select all verts and fill it in to create a face; extrude it to make it 3d; move it into the sphere; Boolean modifier on the sphere set to diffrence.
[Based on the default startup or an attached .blend file (as simple as possible)]bug report.blend
Added subscriber: @Mat-8
Added subscriber: @mano-wii
The "Exact" solution of the Boolean, depends on the orientation of the faces.
In the case of the attached file, the orientation is inconsistent:
For the "Fast" solution, this is a known issue and has already been reported (See #47030).
Try adjust the normals with the command to Flip Normals in {nav Mesh > Normals > Flip}
