Using bpy
module with multiprocessing
causes ModuleNotFoundError: No module named '_bpy'
#98534
9 Participants
Reference: blender/blender#98534
Operating system: macOS Monterey (12.4)
Graphics card: M1 Pro
Broken: 3.1
Worked: -
Hello,
I'm using Blender through the
bpy
module and I noticed usingbpy
module withmultiprocessing
causes a ModuleNotFoundError error. I just wanted to draw Blender developers attention to this bug.How to reproduce the crash
Create
bug.py
with this content, and runpython3 bug.py
:You will get the following traceback:
Why does it happen?
A few discussion/threads have already touched on this issue and here is a summary from here nicely describing why this error happens in essence:
Hacky Workarounds
I also found a couple of hacky workarounds:
sys.path
beforeimport bpy
. And restore it right before instantiating the multiprocessing object. Once done, revert your change. Code, orimport bpy
to avoid re-importing it:Added subscriber: @emadpres
Added subscriber: @ideasman42
Thanks for the detailed description of the error. If I understand this correctly the error is caused by there being two
bpy
modules../bpy.so
./3.3/scripts/modules/bpy/__init__.py
Once C/Python module is loaded, spawned subprocesses find the second one which has not loaded the C/Python module
_bpy
whichbpy.so
defines.There are probably a few ways to resolve this, although I'm currently unable to reproduce the bug, the example code provided loads the Blender module and exists, tested with a build from running:
make bpy lite
.Could you show an example that spawns processes that attempt to use the bpy module?
Hi Campbell and thanks for your following up. I used
make bpy
to build the Blender module. The error happens on my mac (arm64), but not on my ubuntu machine. Are you on macOS or other operating systems?@emadpres I'm using Arch Linux, it seems this may be spesific to macOS.
@ideasman42 Yes, it is specific to macOS. It doesn't occur in Ubuntu for me.
Any update on the issue?
Added subscriber: @Alexander-Hartmann
This comment was removed by @Alexander-Hartmann
@Alexander-Hartmann, as this isn't related to
multiprocessing
module, best make a new report.ok deleted, until ##multiprocessing## I could not run yet
Added subscriber: @timodriaan
Removed subscriber: @Alexander-Hartmann
Added subscriber: @muhuk
Added subscriber: @TobiaszunfaKaron
It seems I am having the same problem on Windows 10.
When using Grid UV Packer in Blender 3.4.1 it seems to freeze blender with this console output:
It seems OS-specific because multiprocessing uses the "spawn" start method on MacOS and Windows, and "fork" as default on Linux. This problem occurs only if the start method is set to "spawn". Although everything seems to work nicely with the fork, I need the spawn method to initialize the CUDA context in subprocesses, as of Blender 3.6 it still doesn't work.
Note that you cant set the "fork" start method in non-Linux operating systems as it is not supported.
