Regression: Crash drag-dropping collection from outliner to ID property #98715
Closed
opened 2022-06-09 09:52:44 +02:00 by Sergey Sharybin · 7 comments
Operating system: macOS-12.4-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon PRO W6800X OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.54
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-07 18:08, hash: 173a15bcda, also broken in 3.1
Worked: 2.93.9
Caused by 3e32a68f38
Drag-dropping collection from outliner to an ID property defined as Python type and which already has a value in it will lead to crash.
  • Open attached file
  • Drag MyCollection from outliner
  • Drop it into the value field of the prop1 property of the scene
IDProperty.blend
Stack trace:
(lldb) bt
* thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0)
  * frame #0: 0x0000000000000000
    frame #1: 0x00000001029fedea Blender`ui_textedit_begin(C=0x00006000033052c8, but=0x0000000131a3f808, data=0x000000015fa2b048) at interface_handlers.c:3484:23
    frame #2: 0x00000001029fe2b3 Blender`button_activate_state(C=0x00006000033052c8, but=0x0000000131a3f808, state=BUTTON_STATE_TEXT_EDITING) at interface_handlers.c:8333:5
    frame #3: 0x00000001029fdfc6 Blender`ui_but_set_string_interactive(C=0x00006000033052c8, but=0x0000000131a3f808, value="MyCollection") at interface_handlers.c:2966:3
    frame #4: 0x0000000102a3f8af Blender`drop_name_invoke(C=0x00006000033052c8, op=0x0000600003505978, UNUSED_event=0x0000600003279d48) at interface_ops.c:1951:5
    frame #5: 0x0000000100f8fcfa Blender`wm_operator_invoke(C=0x00006000033052c8, ot=0x0000600003bd55e8, event=0x0000600003279d48, properties=0x0000600000264a88, reports=0x0000000000000000, poll_only=false, use_last_properties=true) at wm_event_system.cc:1389:16
    frame #6: 0x0000000100f8f9b9 Blender`wm_operator_call_internal(C=0x00006000033052c8, ot=0x0000600003bd55e8, properties=0x0000600000264a88, reports=0x0000000000000000, context=WM_OP_INVOKE_DEFAULT, poll_only=false, event=0x0000600003279d48) at wm_event_system.cc:1630:16
    frame #7: 0x0000000100f95507 Blender`wm_handlers_do_intern(C=0x00006000033052c8, win=0x0000000136524158, event=0x0000600003279d48, handlers=0x000000013652b410) at wm_event_system.cc:3187:35
    frame #8: 0x0000000100f93cc0 Blender`wm_handlers_do(C=0x00006000033052c8, event=0x0000600003279d48, handlers=0x000000013652b410) at wm_event_system.cc:3285:16
    frame #9: 0x0000000100f98a5e Blender`wm_event_do_region_handlers(C=0x00006000033052c8, event=0x0000600003279d48, region=0x000000013652b2d8) at wm_event_system.cc:3705:10
    frame #10: 0x0000000100f94dc1 Blender`wm_event_do_handlers_area_regions(C=0x00006000033052c8, event=0x0000600003279d48, area=0x0000600003880848) at wm_event_system.cc:3735:10
    frame #11: 0x0000000100f934a5 Blender`::wm_event_do_handlers(C=0x00006000033052c8) at wm_event_system.cc:3932:23
    frame #12: 0x0000000100f848d7 Blender`WM_main(C=0x00006000033052c8) at wm.c:623:5
    frame #13: 0x000000010017dbe3 Blender`main(argc=1, argv=0x00007ff7bfeff7e0) at creator.c:547:5
    frame #14: 0x000000012eba951e dyld`start + 462
**System Information** Operating system: macOS-12.4-x86_64-i386-64bit 64 Bits Graphics card: AMD Radeon PRO W6800X OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.54 **Blender Version** Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-07 18:08, hash: `173a15bcda`, also broken in 3.1 Worked: 2.93.9 Caused by 3e32a68f38 **Short description of error** Drag-dropping collection from outliner to an ID property defined as Python type and which already has a value in it will lead to crash. **Exact steps for others to reproduce the error** - Open attached file - Drag MyCollection from outliner - Drop it into the value field of the `prop1` property of the scene [IDProperty.blend](https://archive.blender.org/developer/F13141216/IDProperty.blend) Stack trace: ``` (lldb) bt * thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0x0) * frame #0: 0x0000000000000000 frame #1: 0x00000001029fedea Blender`ui_textedit_begin(C=0x00006000033052c8, but=0x0000000131a3f808, data=0x000000015fa2b048) at interface_handlers.c:3484:23 frame #2: 0x00000001029fe2b3 Blender`button_activate_state(C=0x00006000033052c8, but=0x0000000131a3f808, state=BUTTON_STATE_TEXT_EDITING) at interface_handlers.c:8333:5 frame #3: 0x00000001029fdfc6 Blender`ui_but_set_string_interactive(C=0x00006000033052c8, but=0x0000000131a3f808, value="MyCollection") at interface_handlers.c:2966:3 frame #4: 0x0000000102a3f8af Blender`drop_name_invoke(C=0x00006000033052c8, op=0x0000600003505978, UNUSED_event=0x0000600003279d48) at interface_ops.c:1951:5 frame #5: 0x0000000100f8fcfa Blender`wm_operator_invoke(C=0x00006000033052c8, ot=0x0000600003bd55e8, event=0x0000600003279d48, properties=0x0000600000264a88, reports=0x0000000000000000, poll_only=false, use_last_properties=true) at wm_event_system.cc:1389:16 frame #6: 0x0000000100f8f9b9 Blender`wm_operator_call_internal(C=0x00006000033052c8, ot=0x0000600003bd55e8, properties=0x0000600000264a88, reports=0x0000000000000000, context=WM_OP_INVOKE_DEFAULT, poll_only=false, event=0x0000600003279d48) at wm_event_system.cc:1630:16 frame #7: 0x0000000100f95507 Blender`wm_handlers_do_intern(C=0x00006000033052c8, win=0x0000000136524158, event=0x0000600003279d48, handlers=0x000000013652b410) at wm_event_system.cc:3187:35 frame #8: 0x0000000100f93cc0 Blender`wm_handlers_do(C=0x00006000033052c8, event=0x0000600003279d48, handlers=0x000000013652b410) at wm_event_system.cc:3285:16 frame #9: 0x0000000100f98a5e Blender`wm_event_do_region_handlers(C=0x00006000033052c8, event=0x0000600003279d48, region=0x000000013652b2d8) at wm_event_system.cc:3705:10 frame #10: 0x0000000100f94dc1 Blender`wm_event_do_handlers_area_regions(C=0x00006000033052c8, event=0x0000600003279d48, area=0x0000600003880848) at wm_event_system.cc:3735:10 frame #11: 0x0000000100f934a5 Blender`::wm_event_do_handlers(C=0x00006000033052c8) at wm_event_system.cc:3932:23 frame #12: 0x0000000100f848d7 Blender`WM_main(C=0x00006000033052c8) at wm.c:623:5 frame #13: 0x000000010017dbe3 Blender`main(argc=1, argv=0x00007ff7bfeff7e0) at creator.c:547:5 frame #14: 0x000000012eba951e dyld`start + 462 ```
Author
Owner
Added subscriber: @Sergey
Member
Member
Added subscribers: @JulianEisel, @lichtwerk
Member
CC @JulianEisel: seems like UI_but_func_search_set hasnt been done for that button?
Setting to High prio since it is a regression (even though a bit dated...)
Caused by 3e32a68f38 CC @JulianEisel: seems like `UI_but_func_search_set` hasnt been done for that button? Setting to High prio since it is a regression (even though a bit dated...)
Philipp Oeser changed title from Crash drag-dropping collection from outliner to ID property to Regression: Crash drag-dropping collection from outliner to ID property 2022-06-09 11:46:17 +02:00
This issue was referenced by 589a8104c3
This issue was referenced by 589a8104c34b163ab03f8499440ea7f5d4f20193
This issue was referenced by 4475c38c5c
This issue was referenced by 4475c38c5c9a0e1c5bb48d6fec07cbf58d98abcd
Member
Julian Eisel self-assigned this 2022-06-14 11:57:50 +02:00
5 Participants
Reference: blender/blender#98715
