Z depth not correct when using a volume shader #98857
Reference: blender/blender#98857
Operating system: Linux-5.13.0-48-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce GTX 980/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.129.06
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
e05e1e3691
Z depth gives strange "far away values" when using volume shader and thus cant be used for compositing
Just render this blend file
Zmist.blend
Added subscriber: @thierrykobyleski
Added subscriber: @narcissotto
What is the behavior you expect from this setup? Were you attempting to follow a tutorial? If you could explain what you would like to happen and why, we might be able to find a better method.
Okay, wait, just from context clues and mucking around a bit, I think I found what you were looking to accomplish. The thing that tipped me off was this Note here: "The Z pass only uses one sample. When depth values need to be blended...use the mist pass." Just from a high-level intuition standpoint (I don't claim any knowledge of Z Depth's inner workings), grainy stuff like that can usually be attributed to "undersampling."
When you check the box next to Mist in "View Layer Properties," then back in the Compositing node editor plug Mist directly into Mix's Fac input, it properly mixes the suzanne with the red background. I've attached a file with it "fixed." Hope this was what you're looking for!
Zmist_proper.blend
I am trying to create some mist with a volume shader for my middleground landscape, while the background is a landscape photograph which I don't want to alter with my volume shader since the photograph already contains its own mist (just a thin haze of air humidity).
With your file Zmist_proper.blend the background can be seen through suzanne.
I made a try using the mist pass distance and adding a background photograph, and a plane for the ground. Here is what I obtain
The new blend file
Zmist_proper_PB.blend
New try without film transparency, and with a threshold on the mist pass socket
I obtain what I expected
Here is the blend file
Zmist_proper2.blend
Thank you very much. The problem is solved for me, with this unexpected solution where the mist distance is used to show the background photograph, while the mist is obtained from the volume shader alone.
Added subscriber: @mano-wii
I'm not sure what the expected depth value should be when there is a volume in the scene, but this randomness doesn't seem to be ideal.
So I'm confirming it as a bug for now.
Thanks you. I will try again with "Z value" instead of "mist value" when the bug will be fixed.
Still presents today with 4.2 alpha, it's been such a long time...
z depth channel with camera inside a volume fog object↑↑↑
Because of this, I have to stop making volumetric things inside blender sadly
