Texture nodes CPU evaluation design #98940
13 Participants
Reference: blender/blender#98940
For #54656, we need CPU evaluation of a subset of shader nodes that form the texture nodes.
Prototype under development in D15160.
Overview
The plan is to make this a subset of geometry nodes that can be evaluated using the same mechanisms. Texture nodes can be though of as a geometry nodes field, and when evaluated in the context of geometry nodes they are.
However they can also be evaluated outside of a geometry node tree. In particular, they can be evaluated on:
To support the last two cases in the geometry nodes infrastructure (but not the geometry node evaluation itself), a new field context named
TextureFieldContext
is added. This represents a continuous texture space, that may be mapped to a geometry surface or not. It has one domain,ATTR_DOMAIN_TEXTURE
.Compilation and Execution
The texture nodes compilaton and evaluation mechanism uses much of the same infrastructure as geometry nodes, but is separate to be usable in different contexts. It's meant to be possible to execute texture nodes efficiently many times, for example paint brushes are multi-threaded and each thread may execute the nodes multiple times. This is unlike geometry nodes where multiple threads may cooperate to execute nodes once.
The current compilation mechanism is as follows:
MFProcedure
, which bundles multiple multi-functions into one for execution. Geometry nodes do not currently use this mechanism, but it is designed for this type of evaluation. This is rather inefficient currently for individual points, but should get more efficient when evaluated in big batches.geometry_node_execute
as part of compilation, which then outputs fields and values. The execution context for these nodes is limited, unlike geometry nodes there is no geometry, object or depsgraph.GVArray
using the provided geometry.We could consider making geometry available and to the compilation and caching the compilation per geometry, though it's not clear there will be nodes that need this. Alternatively we may cache just the
GVArray
per geometry.Fields
Input nodes return fields, which are then turned into
GVArray
for evaluation. For the texture domain, this is a virtual array that interpolates attributes. There may be some possibility here to share code with data transfer field nodes, or nodes that distribute points and curves on surfaces and inherit attributes.Shader nodes need additional fields that are not currently in geometry nodes:
It's unclear to me what the best way to specify these as fields is, if we should add additional builtin atttribute names or
GeometryFieldInput
. Some of these like Pointiness would also make sense to cache as attributes, and make available to external renderers.One constraint is that it must be efficient to evaluate only a small subset of the domain. For many field inputs and operations this works, but there are some that will compute a data array for the entire domain. This can be enforced by just not making such nodes available as texture nodes, or caching the data array on the geometry.
For sculpt and paint modes, there is a question if and how we can make all these attributes available. The challenge is that it has different mesh data structures (bmesh and multires grids), which are not supported by geometry nodes. Additionally, recomputing for example tangents and pointiness as the geometry changes during a brush stroke would be inefficient, especially if it's for the entire mesh and not just the edited subset.
Batched Processing
Fields and multi-functions are not optimized for evaluating one point at a time, there is too much overhead. That means we want to process texture evaluations in batches, and all (non-legacy) code that uses textures should be refactored.
For geometry nodes, modifiers and 2D brushes this is most likely straightforward. However for 3D brushes, particles and effectors it will be more complicated.
There is currently a mechanism to single evaluations possible while code is being converted. However this is rather inefficient, with quite a bit of overhead in
MFProcedure
execution. It may be possible to do some optimizations there for legacy code that we may not be able to easily convert to batches.Node Graph Transforms
To support sockets like Image datablocks, and to automatically insert Texture Coordinate or UV Map nodes for textures coordinate sockets, we need to transform the node graph. The texture node layering will also need to do significant node graph transformations. In order to share code with Cycles and other external engines, it may be best to do this as part of node tree localization.
Relation to Other Node Systems
There are many node evaluation systems in Blender, and the question is if we can somehow share this implementation with anything else. I don't think the CPU evaluation can be directly shared, but will make the old texture nodes evaluation obsolete at least. The GPU implementation can probably be largely shared with shader nodes, and that implementation could be refactored to use DerivedNodeTree for consistency and to simplify that code.
Added subscribers: @brecht, @HooglyBoogly, @JacquesLucke
Overall this seems to be going in the right direction, but it feels like there is still a little bit of confusion regarding the link between geometry nodes, field and multi-function evaluation. So I'll try to describe those below. Part of what makes it difficult to separate these concepts currently is that they are only used in one specific combination right now.
The first important thing to note is that these three concepts are not inherintly linked. Geometry nodes evaluation can exist without fields or multi-functions. Fields can exist without geometry nodes or multi-functions. Multi-functions can exist without geometry nodes or fields. Let me try to explain each concept on its own:
bNodeSocket
) is assigned aCPPType
. The data flow defined by abNodeTree
is then evaluated. For this evaluator, there is no difference between sockets that can be fields and those that can't be. It's all just a fixedCPPType
per socket type (e.g.GeometrySet
for geometry sockets andValueOrField<int>
for integer sockets). In the implementation in master, the geometry nodes evaluator still knows about fields, but that changes with #98492.838c4a97f1
. For evaluation, a field can be converted intoMFProcedure
(as is done now), or it could be converted to a latency optimized function, or it can be used to generate shader code that runs on the GPU. All of that also makes sense when just considering geometry nodes (we may want to evaluate some fields on the gpu as well in the future).Given those definitions, it seems like texture and material shader
bNodeTree
evaluation could be handled by the geometry-nodes evaluator (which shouldn't be called that anymore then). Note that this evaluation does not actually compute the texture values, but it just builds e.g. aField<Color>
(a color depending on some inputs). This field can then be converted to a multi-function in geometry nodes (as is done now), or it can be converted to shader code that can be used by Eevee. The more tricky thing is to get this field into cycles. This could be done by either providing some RNA api or by serializing it somehow (afaik, standalone Cycles can already read materials from XML?).This approach has the advantage that there are fewer places in Blender that have to deal with evaluating a
bNodeTree
. That localizes the complexity that comes from dealing with node groups, implicit inputs, implicit type conversions, reroutes and muted nodes. On top of that, concepts that are currently only planned for geometry nodes like loops could also by used in material nodes (it's just a different way to construct a field, the number of loop iterations can't depend on the field context in this case). Furthermore, it also allows us to use the same visual language to differentiate between fields and single values used in geometry nodes, which can also help add support for input sockets for the image texture node.Given the rough proposal outlined above, the following section comments on various parts of the original proposal.
Maybe better to say: Texture nodes are a way to construct a color field that's used by a texture.
I don't see how that fits in. Do you suggest making textures a geometry component that can be stored in
GeometrySet
?It would be more correct to say: For every field-input, a
GVArray
is created using the provided geometry.From what I can tell, all of these could potentially work in geometry nodes as well, if we want that.
Good question. I think for everything that is actually a named attribute (a data layer that can be edited by the user), just storing the attribute name in the
FieldInput
should be good enough. For anything that may need more preprocessing based on the context, a different subclass ofFieldInput
should be used. I don't think we should give attribute names to derived data (we can still use names if it helps, but those must not be confused with attribute names). Note that we may have to generalizeFieldInput
a bit here, it shouldn't have to know about the concept ofGVArray
.I agree with the caching part, but not with the fact that these are "attributes" in a more strict sense. That's because this data cannot be changed by the user directly. Instead, it is derived data (which is also why we want to cache it).
I think the reasoning implied here is a bit backward. Processing elements in batches can be implemented much more efficiently then processing one element at a time. Therefore the multi-function system is optimized for that. And that is also the reason why we should refactor other parts of Blender to process data in batches. Note, while multi-functions are optimized for evaluating batches of data, fields are not. Fields don't care if you process one element or multiple elements at a time, because fields themselves are not an evaluation system, just a way to compose functions dynamically.
Still feels doable, but I can see why this would be more difficult. One "just" has to do some loop fission (as opposed to fusion). It may feel like that would be adding a lot of overhead, from what I've learned so far is that this is generally worth it. When the textures become a bit more complex it could be more than an order of magnitude faster to evaluate it in batches than one element at a time (also there are way more optimization opportunities).
Personally, I wouldn't want to implement these kinds of transformations on the
bNodeTree
level. That limits what kind of transformations are possible quite a bit. It also leads to IMO weird changes like what was done in80859a6cb2
. It added unavailableWeight
sockets to various nodes for the needs of one specific evaluation system.Can you describe what kind of node graph transformations you have in mind?
I wonder what's the expected timeline for this project? I realize that some of the things I suggest require quite a few changes and that we probably want to break this project down into smaller steps. It's still good to have an idea of where we want to go longer term.
For Cycles and external renderers in general, I don't think we want to use fields in the renderer. The longer term in Cycles likely involves more OSL, MaterialX and Hydra, and all those deal with node graphs. Having some alternative way of passing field based shaders from Blender, and node based shaders from other sources is going to have too much complexity. And this would not just be for Cycles, but also external renderers, or file I/O with USD, glTF, MaterialX, etc.
Even disregarding that, I think there is important conceptual difference in how shader and geometry nodes work. Shaders are meant to be decoupled from specific geometry, they will reference some attribute names and image textures, and then the render will match those to what's on the geometry at render time. Shaders only have access to local information at a shading point, not to the geometry as a whole. Being able to couple it more tightly to geometry has some interesting possibilities, but decoupling is also a powerful, and for better or worse that's the industry standard way of handling materials.
For geometry nodes it's fine for fields to be a black box that can do whatever, but for shaders
Field<Color>
is not enough. I think it's possible to let the geometry nodes evaluator handle CPU texture evaluation and perhaps even Eevee shader compilation. But at least with the conceptual picture of shader and texture nodes I have now, it may be messy to have a single evaluator that handles both.I think localizing the complexity of all those things is helpful, but as mentioned many of the systems we want to interoperate with don't work with fields as a concept. For them it would be better to have a node graph that has all those things applied.
The intent would be to use this only in the context of texture nodes evaluation, so it would never get stored in a GeometrySet. I could imagine a future where an image texture becomes a type of geometry handled by geometry nodes, but not sure that makes a lot of sense.
3D brushes we have to add batching for. I'm hoping that for particles and effectors I don't have to refactor that legacy code, but it's certainly possible with effort.
It's a trade-off, the weight sockets are ugly but a completely different node graph representation also adds complexity. It's not clear what the alternative is assuming we want interop with external renderers and file formats.
It would be for the layer socket type and layer stack node that bundle multiple texture channels, as well as baking. Following the design here.
https://code.blender.org/2022/02/layered-textures-design/
The layer socket and stack node could be converted into a bunch of mix nodes for all the the texture channels. For baked textures, the texture nodes would be replaced by either attribute or image texture nodes that read the baked results instead of doing procedural evaluation.
In principle the texture project is meant to be worked on this year. Some initial parts to replace old texture nodes could be in 3.4, with a more complete implementation for 3.5 or 3.6? But it's hard to say.
Added subscriber: @GeorgiaPacific
This is getting very theoretical at this point, but I will say, that sounds exactly like the concept of fields to me. They describe an instructions, not the context, and can only be evaluated when some context describes an input.
Anyway, that's not so important, I think the idea of using fields for shaders was more of a theoretical point. I do think it's important to distinguish the "evaluator" that creates a field from a node tree and the evaluator that provides context and evaluates the field though.
I don't have much to add about interoperability or node graph transformation discussion, besides that doing it elsewhere besides
bNodeTree
is cleaner in my opinion. But that's a tricky issue.About the texture "geometry component", I see that making more sense as a separate field context. So the "geometry field context" wouldn't be reused, but instead an "image field context" would give image's values for a certain position.
I'd think that interpolating attributes data from a geometry would be implemented as specific field operations (and then multi-functions or shaders).
Refactoring to use batched evaluation for sculpting does seem like quite an undertaking, but I do think it would be worthwhile for other reasons too.
Sorry if I'm repeating something we've already discussed, just coming back to this topic after a while.
It is the same thing at the conceptual level, just the implementation requirements are different.
I'm not sure where elsewhere would be, introducing another node graph data structure that then also needs to be exposed in the Python API seems like too much complexity.
I've changed it to field context now.
Added subscriber: @zNight
Added subscriber: @ecosky
Added subscriber: @mod_moder
Added subscriber: @silex
Added subscriber: @blendersamsonov
Added subscriber: @simen
Added subscriber: @Pancir
Added subscriber: @johannes.wilde
Added subscriber: @DanielGrauer
