FBX export active collection - exports all collections in the scene instead of active collection only #98945
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#98945
Operating system: W10 21H2
Graphics card: RTX 3060Ti
Broken: 2.93 up including latest 3.2
Worked: 2.90
Missing checkbox in outliner for linked collections. Upon export to FBX it exports all collections instead of active only.
Create two cubes, scale on of them and put them to separate collections
Save the file and create a new one.
Link previously created collections. Hide collection B and select collection A. Export it to FBX with ticked checkbox Active Collection
Create a new file again and import FBX we created previously. Check the result in outliner. There are two objects, instead of just one, even it is empty.
Result
Expected result
I found a workaround but it is a bit annoying to do for every linked collection. Create a collection and then put linked collection to it. Now there is checkbox which i can use to hide all other collections and export only the one i want.
I am not sure whether it is a bug or intended design.
Thanks for checking.
Added subscriber: @PaloPiktor
Added subscriber: @iss
Can confirm the issue, but 2.90.1 seems to behave like this either.
Added subscriber: @mont29
You are confusing collections and collection instanced as Empty objects here.
The
Active Collection
option only affects actual collections added to the current View Layer, NOT Empty objects instantiating a collection, which what you show in your second screen cap. Those are essentially objects, not collections at all.NOTE: linking by default currently instantiate linked collections into local Empty objects, you can instead get it to put the linked collection into the active ViewLayer by disabling the
Instance Collections
in the linking options.
