Segmentation fault while texture painting #99015
5 Participants
Reference: blender/blender#99015
Operating system: Linux-5.15.0-37-lowlatency-x86_64-with-glibc2.35 64 Bits
Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.129.06
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
e05e1e3691
Worked: -
Attempting to texture paint on certain models results in segementation fault.
Open the attached blend file, start painting on forearm_drone_kit.L (texture to paint on: DroneController, 2K)
os_info.txt
blender_3_2_0_segfault_while_painting.blend
blender_3_2_0_segfault_while_painting.crash.txt
Added subscriber: @peterf-2
Forget to mention in the original post: painting in the 3D view causes the crash, painting in the 2D image view still works.
Added subscriber: @lichtwerk
Changed status from 'Confirmed' to: 'Needs User Info'
getting crashes in 3.1, 3.0.1, 2.93 as well
The mesh seems corrupt, the following returns True
After that, painting succeeds.
@peterf-2 : got an idea how this thing got corrupted?
@lichtwerk: After C.active_object.data.validate_material_indices() it works on my side as well. Also can confirm that the error is present in older versions, while painting on the default cube works as expected.
No idea what went wrong, I did some fairly ugly booleans, though. If I read the help for validate_material_indices correctly, the issue was that individual polys got different material indices. What kind of operations could cause this? My workflow was this:
Could any of these lead to this interesting error?
(I will continue working on the project to see if Ithe issue pops up again)
Thanks for the quick help!
I would suspect the booleans (of different objects with different materials) to somewhat leave invalid indices, not sure though.
Maybe you could run some tests if these lead to the buggy behavior?
Any particular tests in mind? Or shall I just go nuts with the booleans?
Added subscriber: @jack.herbert
I got that bug with a model made using boolean operations, also on Linux with an Nvidia card, and running the validate_material_indices line returns True and fixed it.
Do you have an example file prior to applying the booleans that then crashes once the booleans are applied?
Sadly no, I have a save from shortly after applying the modifier, don't know if that's any use but here it is:
texture-paint-crash.blend
Some observations:
Added subscriber: @JosephEagar
I can add a check in the paint code for invalid material slots. That said, we really should track down the booleans bug; I think I ran into it a few weeks ago.
Since we do not have an example with the boolean modifier still active (not applied) and also since there have been related fixes (see
a2d59b2dac
&1a6d0ec71c
) I would assume the current situation has improved in 3.2.2 onwards (in that we hopefully dont run into this situation again).That does not mean the original file is fixed, for that
is still necessary to fix the corruption.I'll put this on hold for now, please use newer blender builds/versions and report back if you run into this situation again.
