Rigify root scaling bug #99476
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#99476
Operating system: Win 10
Graphics card: 1660
Broken: (example: Any build since 3.0.0 (I have updated to each variation of 3.1.0/3.2.0/3.2.1/3.3.0, existant in all versions)
Worked: (None.)
(No string it's an animating and weight painting occurrence)
A bug exists in the "DEF-spine.005" bone and the "root" bone related to scaling the root bone.
(upgrading face rig has no influence)
After painting weights on the "DEF-spine.005" bone's vertex groups and going into pose mode you will run into an issue while scaling the "root" bone.
Regardless of positive or negative scaling of the root bone the neck bone will scale into the opposing direction, turning off the copy transform for the neck bone causes the issue to go away but it's but a work around.
My current work around is not using the DEF-spine.005 bone and using the DEF-spine.004 bone instead, however i'd like full neck motion which would require the DEF-spine.005 bone as my models require root bone scaling.
bug_report.blend
Added the scaling issue as animation.
Added subscriber: @Savage_Feast
Added subscriber: @OmarEmaraDev
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I can replicate the issue, but I am not sure if it is a bug. So will wait for a developer to look into this.
Closed as duplicate of blender/blender#98490
