Regression: behavior of Separate/Delete Geometry nodes changed in 3.3 #99667
Reference: blender/blender#99667
In the setup below, the output is an empty geometry in 3.3, while the mesh line is still there in 3.2. The old behavior is correct, since the Delete Geometry node should only delete faces here. When there are no faces, it shouldn't do anything.
This is caused by
c4e11122c5
. It's most likely an issue with the order of domain interpolation and selection inversion. Either that should be fixed by, or the commit should be reverted.This was found in #99664.
delete_geometry_deletes_too_much.blend
Added subscribers: @JacquesLucke, @HooglyBoogly, @wannes.malfait
Behavior of Separate/Delete Geometry nodes changed in 3.3to Regression: behavior of Separate/Delete Geometry nodes changed in 3.3Although #99664 (Delete Geometry node face mode behaves unexpectedly when used after Join Geometry) shows a bigger problem, I think this specific regression is caused by this check here:
When the selection is empty, this doesn't return, while in the old version it did. So adding a check for empty selections would probably fix this:
(selection.is_empty() || (selection.is_single() && selection.get_internal_single()))
If #99664 were fixed, then this check wouldn't affect the outcome, just how long the node takes.
Sounds reasonable, want to create a patch?
Sure: D15445: Fix #99667: Regression in Delete Geometry node
This issue was referenced by
7561183830
