Textures mapped on UVs with very high location values appear emissive when rendering on CPU #99795
2 Participants
Reference: blender/blender#99795
Textures mapped on UVs that have vertices with very high location values appear emissive or black with CPU rendering. The UV vertex location values are around the range -3960966.
Original Report
Operating system: macOS Monterey 12.4
Graphics card: Apple M1 Max
Broken: In every version I can find but for example in 3.2.1 2022-07-06 and 2.80 2019-07-29 as well as the nightly alpha 3.3.0 2022-07-17
Worked: Cannot find a version in which it works.
system-info.txt
Background
I'm generating images in python using a script and I load objects from a dataset called SceneNet. Some of these objects have poor UV mapping, which is not a big deal, but it's causing rendering artifacts which are a problem.
The Bug
When a surface has incorrect UV mapping and has a stretched out texture, it leads to the surface becoming extremely bright. It does not emit light, the issue only occurs when there is a light source, emissive surface, or world background in the scene. The surfaces with stretched textures seem to multiply the reflected light by a high factor.
In the viewport the issue only occurs when rendering on CPU. When rendering on GPU, the texture looks stretched out but with the correct color and not bright.
Example 1:
GPU ONLY CPU
Example 2:
GPU ONLY CPU
Example 3, the same scene but with UV mapping fixed for part of the wall:
CPU
Example 4, blender 3.3.0 2022-07-17:
GPU CPU Replaced problem faces with 100% white diffuse material
When rendering to file, I have seen two cases:
Desired behavior:
The result from pure GPU rendering is the desired behavior.
Open attached .blend file, change viewport to render, switch between GPU and CPU rendering to see the difference. Try render to file using CPU/GPU/Mixed.
bug-textures.blend
Added subscriber: @karl_12345
Additionally, in the Blender render window the problematic faces look darker than in the renders
Added subscriber: @OmarEmaraDev
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I can confirm that, but this could be a known limitation, because UVs have very high values, in the range around -3960966, so they could be prone to limited precision computations. So tagging the module for more information.
Incorrectly mapped textures reflects light incorrectly only when rendering on CPUto Textures mapped on UVs with very high location values appear emissive when rendering on CPU
