Node Wrangler : Align Nodes operator disregards selection when used on frames #99904
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#99904
Operating system: Linux-5.10.0-16-amd64-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce GTX 1660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.129.06
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash:
blender/blender@e05e1e3691
Worked: I don't remember it ever working (been using Blender since 2.7x).
if a frame node is selected, the Align Nodes button moves all the nodes in the tree, including those that aren't selected.
From the startup file:
Note : This other issue probably needs to be solved first in order to fix this one
Added subscriber: @ChameleonScales
Node Wrangler : Align Nodes is broken when used on framesto Node Wrangler : Align Nodes operator disregards selection when used on framesWhat your describing here isn't a bug with frames, but moreso just weird unintuitive behavior from the operator itself.
Looking at the code for the NWAlignNodes operator, it ignores frames during its execution:
So selecting a frame like you described results in an empty selection. The choice I personally find weird is that if no nodes are selected, it uses all nodes as a selection:
That's why selecting only a frame moves nodes you haven't selected, from the operator's perspective, nothing has been selected so it simply aligns all the nodes in the nodetree.
At least it tries to, a separate but more general bug is happening here where nodes don't get properly aligned when they don't share the same frame, hence why the final result looks random instead of being aligned as one line.
Addressing this issue would be separated into two parts:
1.) Fixing the general bug of the operator not calculating positions properly when multiple frames are involved. Though this is a more secondary concern, as this isn't related to the selection being ignored, this just fixes the nodes being seemingly placed at random when framed nodes are aligned.
2.) Remove the part where the operator aligns all nodes when none are selected. This is the more immediate concern in this issue. It doesn't seem to be intuitive behavior as no nodes being aligned is probably more expected when no nodes have been selected.
Secondly, if a user wanted to align all nodes, they could easily select all nodes with the 'A' hotkey before calling this operator, so no actual functionality is being lost if the operator just ends execution early when no nodes have been selected.
