Rigify doesn't load on 3.2 Blender version and above #99931
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#99931
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: GeForce GT 630/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash:
blender/blender@a2d59b2dac
Addon Information
Name: Rigify (0, 6, 6)
Author: Nathan Vegdahl, Lucio Rossi, Ivan Cappiello, Alexander Gavrilov
Trying to enable Rigify first time after opening Blender provides this error:
Rigify-error-01.txt
All the next attempts giving this error in response:
Rigify-error-02.txt
Enable Rigify without regard to settings, opened scene, or other enabled addons
Added subscriber: @Mark-10
Added subscriber: @Alex_Rom
Removed subscriber: @Alex_Rom
Added subscriber: @OmarEmaraDev
Do you have any feature sets installed? Does the issue persists even with them removed?
If yes, maybe try updating this feature set?
There are two of them here, but I'm unable to interact with feature sets with addon disabled. I tried to do it through files by deleting "rigify" folder in "\Apps\Steam\steamapps\common\Blender\3.2\scripts\addons" and then restoring these files using Steam. Blender gives the same errors
You need to delete
3.2\scripts\rigify
instead, or its contents.There's no
\scripts\rigify
, but there is\scripts\addons\rigify
. Reinstallation of it is also to no availSo there is no
scripts\rigify
, but you can still see feature sets in the add-on preferences?Which feature sets do you have installed?
They show up only with rigify enabled
{F13334015}(the screenshots show the old Blender version)
Experimental Rigs
doesn't show any version and theCloudRig
is 0.0.7I see, it seems they are installed in the user config path. Can you remove the
rigify
folder from the user path, which is probably inC:\Users\leoma\AppData\Roaming\Blender\3.2\scripts\
?If my guess was not accurate, paste the following into the Blender python console to get the path:
Yep. That works. Thanks a lot, Omar
