driver expression not updated in command line rendering and render with lock interface #102807
Reference: blender/blender#102807
Operating system: Macos
Graphics card: M1
Broken: 3.1.0 release version
Worked: don't know
When assign a property with driver expression (such as
#frame
), then write a script to print out the property value at each frame inbpy.app.handers.frame_change_post
, then render animation withlock interface
, or command line rendering (which needs to register the script), then the value printed from python code is not updated, it always prints the same value.Exact steps for others to reproduce the error
untitled.blend
To repro from scratch:
location.x
to#frame
, then write a scriptlock interface
The value printed from python code is incorrect and always the same value
Frame value can be correctly printed, when render without
lock interface
.Because I mostly need it to work in command line rendering, but I found it has the same problem when render with
lock interface
The file
untitled.blend
does the same thing as I talked above, once you open it, run the script, then render the animation, you can see the output in console.Added subscriber: @Hantao-Hui
I did some research into the source code, so the problem I found is at here,
in command line rendering, and render with lock interface,
DEG_is_active(depsgraph)
returns the false, soanimsys_write_orig_anim_rna(&id_ptr, fcu->rna_path, fcu->array_index, curval);
is not executed, then the value is not flushed to the python code/ui side.So I am not sure, if this is designed intentionally, or this is a bug.
A quick fix is to change the code
if (ok && DEG_is_active(depsgraph)) {
toif (ok) {
, then the value can be correctly printed from python. But I don't really know what does depsgraph do, so this is clearly not a good solutionI think this is not a really
M1
related issue, but don't know why it links to this pageChanged status from 'Needs Triage' to: 'Confirmed'
Can confirm this problem on Windows 11 in Blender 3.6, too.
So this is really a massive problem since it basically prevents us from using python script drivers when rendering on a renderfarm. Since the same happens when you are writing a custom driver with python and looking at its ouput or for that matter even writing values directly into a driver expression.
Hi, @Sebastian-Beck ,
just a quick work-around, you can use despgraph to get the correct driver value. Now it prints the correct value when rendering. Something like this
@Hantao-Hui Thanks for the heads up. Will try if i can get this to work for my case.
