Sapling Add-On full of errors. #42138
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
7 Participants
Reference: blender/blender-addons#42138
Windows 8; NVidia GeForce GTX 760
Broken: 2.72
Worked: 2.71
The Sapling Add-On seems partially broken. Changing the preset to the tree type ca_black_oak causes an error:
These statements, though copied from the Blender log panel, appear in reverse order here.
ZeroDivisionError: float division by zero
********************************Although it does not seem to apply any changes, it does cause other errors that do not otherwise occur within the Sapling settings: cannot turn on bevel, cannot make changes to curvature, etc. If, however, I go back to the presets and change it to one of the other settings, like black_tupelo, the errors stop and I can make changes, as you normally would.Exact steps for others to reproduce the error
Open Blender.
Turn on the Sapling Add-On.
Add a Tree curve.
Change the preset to ca_black_oak *error occurs here
Try to make other changes to the tree *error occurs here
Change the preset back to black_tupelo
Added subscriber: @MattLindley
#42010 was marked as duplicate of this issue
blender/blender#42250 was marked as duplicate of this issue
Added subscriber: @BrendonMurphy
hi, after some testing, the issue is when the Limit Import button is checked & only with ca_black oak file.
However, the "ZeroDivisionError: float division by zero" error seems endemic throughout the addons settings.
Prune throws same error as do many other changes.
This addon has no maintainer, https://developer.blender.org/p/trumanblending/ has not been active for some time.
I would add a warning "Buggy" for the immediate future & actively seek out a maintainer to fix current issues.
Added subscribers: @kintoun1, @truman
Added subscriber: @LeeA.Wentzel
Added subscriber: @lichtwerk
Added subscriber: @AditiaA.Pratama
Added subscriber: @NikoLeopold
this should fix the zero by division errors and also make the shape affect first level branches: D844
its just 3 lines of code so you can change it yourself in the addon if you need a quick fix.
looking for review. how does this work for addons?
Assigned to lichtwerk (Philipp Oeser).
he has also written a patch, I would expect fixes to be finalized this week.
ok. i didnt know since it was not claimed yet (and author was said to have no time for maintenance)
great to hear that its being done :)
Thanx for this Nikolaus,
I hope I'll find the time later today or tomorrow to have a final look.
I was more looking into https://developer.blender.org/T42207 which is more about pruning&armatures but hopefully we can solve this all in one go :)
thanks Philipp, i just did a really quick hotfix, there might be more places vulnerable to division by zero errors and other issues. i didnt have more time to test on the weekend unfortunately, just wanted to get it to work quickly :)
thanks for your effort!
Hi again!
Just wanted to say that I think the patch looks good (but I wont be the person to make a final decission here).
I will leave a note (and a WIP patch) about the other problem ('armatures&pruning' aka #42207) in that bugreport.
I am also on another job for at least a week, so I wont be available -- and thus put this up for grabs for anyone to jump in, sorry about that.
If this hasnt been solved, I will pick it up again when the other job is done [still think this addon deserves to be in addons and should be kept alive :)]
i would happily pick it up – you mean the other one, #42207 right?
also i would just extend the current patch of this little problem here to test for more possible vulnerabilities to division by zero and change such to prevent that.
also i wanted to ask who i could ask for code review in the end, since the author is not available..
EDIT: unfortunately i might not be able to look into this until next weekend due to university duties...
This issue was referenced by
51b6f00666
Closed by commit
51b6f00666
