export_obj issue when exporting .blend or unsaved project #45184
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#45184
Windows 8.1, rest not relevent.
Broken: 2.7.4
Exporting an object from a loaded .blend file (or without a save) will result in a lack of "vt"
hoverbike.blend
With my blend file, export the object as an obj with default object exporter.
Look at the "player_atch" object, in the resulting .obj file, and you will notice a lack of "vt".
Then, close blender. Open blender. Import the .obj you exported, and export it in the same manner.
"vt" now exists!
Should also note, due to loops, importing and exporting reverses coordinate order. I'm doubt that affects anything, but worth mentioning.
Added subscriber: @Nocare
Added subscriber: @sindra1961
@mont29 explains it in this report(#45012 ) before.
Added subscriber: @mont29
This issue was referenced by
4c1e066129
Issue is actually with .obj importer, which adds (useless empty) lnor and/or UV layers to split part from .OBJ that have none… Fix incoming.
If I understand correctly Bastien, vt will no longer be inserted when exporting an imported .obj file?
Again, problem was not with exporting, but with importing (was generating UV layers when not needed).
