simple gn node setup won't work #89728
Closed
opened 2021-07-08 11:58:12 +02:00 by Christoph Duyster · 17 comments
Operating system: ?
Broken: version: ?
i have this simple nodes setup here but i only see one circle and hoped for more circles...
gn_circle_prob.blend
system info:
system-info.txt
**System Information** Operating system: ? **Blender Version** Broken: version: ? **Short description of error** i have this simple nodes setup here but i only see one circle and hoped for more circles... **Exact steps for others to reproduce the error** ![image.png](https://archive.blender.org/developer/F10216988/image.png) [gn_circle_prob.blend](https://archive.blender.org/developer/F10216990/gn_circle_prob.blend) system info: [system-info.txt](https://archive.blender.org/developer/F10217021/system-info.txt)
Added subscriber: @LuckyChris
Added subscriber: @rjg
Thank you for your report. Unfortunately, this seems like a request for help with your Blender project and not a bug report.
If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat . The bug tracker is only for bug reports.
In case you believe that you've found a bug, please read [this guide ]] and create a new bug report throughHelp > Report a Bugin Blender. We expect all bug reports to follow the [ https:*developer.blender.org/maniphest/task/edit/form/1/ | submission template . Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
Thank you for your report. Unfortunately, this seems like a request for help with your Blender project and not a bug report. If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance [[ https:*blender.stackexchange.com/ | Blender's StackExchange ]], [[ https:*blenderartists.org/ | blenderartists.org ]] or the [[ https:*blender.chat/channel/support | #support channel on Blender chat ](https:*www.blender.org/community/). The bug tracker is only for bug reports. In case you believe that you've found a bug, please read [this guide ]] and create a new bug report through*Help > Report a Bug*in Blender. We expect all bug reports to follow the [[ https:*developer.blender.org/maniphest/task/edit/form/1/ | submission template ](https:*wiki.blender.org/wiki/User:Rjg/HowToBugReport). Please provide **system information** (operating system, GPU, graphics driver version), **affected Blender version**, previous **Blender version that worked properly**, a **short and precise description of the issue**, step by step **instructions to reproduce it** and, if relevant, **a minimal .blend file that showcases the problem**.
Added subscriber: @MiroHorvath
This actually is a bug, it behaves exactly the same like the bug I reported here https://developer.blender.org/T89417
FYI, if you select Circle.001 object and switch to edit mode you'll see that circle gets instanstanced, read more in the link above.
This actually is a bug, it behaves exactly the same like the bug I reported here https://developer.blender.org/T89417 FYI, if you select Circle.001 object and switch to edit mode you'll see that circle gets instanstanced, read more in the link above. ![image.png](https://archive.blender.org/developer/F10217014/image.png)
@MiroHorvath Thanks for looking into this, I'll reopen the task.
@LuckyChris Please follow the bug submission template for future bug reports though. For this ticket we still need your system information (Help > Save System Info and attach the file to your report).
@MiroHorvath Thanks for looking into this, I'll reopen the task. @LuckyChris Please follow the bug submission template for future bug reports though. For this ticket we still need your system information (*Help > Save System Info* and attach the file to your report).
Changed status from 'Archived' to: 'Needs Triage'
Member
i updated with my system info.
@LuckyChris just FYI you can also do this image.png, it pre-fills all the necessary system info.
@LuckyChris just FYI you can also do this ![image.png](https://archive.blender.org/developer/F10217026/image.png), it pre-fills all the necessary system info.
Thank you Miro!
Thank you Miro!
Member
For sure the report is duplicate of #89417 (Only one instance shown if object being instanced consists only of verts and edges)
@rjg , I am marking this as duplicate report :)
like #89417, all instances are only visible in edit mode
Thanks @MiroHorvath :)
For sure the report is duplicate of #89417 (Only one instance shown if object being instanced consists only of verts and edges) @rjg , I am marking this as duplicate report :) like `#89417`, all instances are only visible in edit mode Thanks @MiroHorvath :)
Member
Closed as duplicate of #89417
@MiroHorvath already mentioned that in the first comment + a link to a how-to guide ;)
In #89728#1188522, @rjg wrote:
In case you believe that you've found a bug, please read this guide and create a new bug report through*Help > Report a Bug// in Blender.
@LuckyChris Apologies for closing your ticket too soon. We commonly get tickets where people just want help with their project. This initially looked like one of them and I didn't check the file first.
@MiroHorvath already mentioned that in the first comment + a link to a how-to guide ;) > In #89728#1188522, @rjg wrote: > In case you believe that you've found a bug, please read [this guide ](https:*wiki.blender.org/wiki/User:Rjg/HowToBugReport) and create a new bug report through*Help > Report a Bug// in Blender. @LuckyChris Apologies for closing your ticket too soon. We commonly get tickets where people just want help with their project. This initially looked like one of them and I didn't check the file first.
@rjg : No problem. I wasn't really sure whether it was a bug or not. And sorry it was a duplicate. I am still not good in finding already added tasks here :(
@LuckyChris if you're not sure it's a bug I recommend to ask at https:*blender.chat/channel/everything-nodes or https:*blenderartists.org/t/geometry-nodes/1264425
Reference: blender/blender#89728
