Regression: Geometry nodes: Object info does not care if referenced obejcts subdivision surface modifier is disabled #99058
7 Participants
Reference: blender/blender#99058
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.95
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-20 22:42, hash:
a18c291435
Worked: 3.2.0
Caused by
ca9d65cc97
As in Title
I might be misunderstanding things, but it seems to be the inverse of https://developer.blender.org/T96264
However, this doesn't seem to be linked to GPU subdivision, since it is also the case if GPU subdivision is disabled, and/or the subdiv is not the last modifier int eh stack (which should also disable it)
Obejct info.mp4
Ensure GPU subdivision is disabled
Add two objects
Add a subdivision surface modifier to one of the objects and disable it
Add a geometry nodes modifier to the other object
Add an object info node to the GN tree and reference to other obejct
Plug the geometry output of the obejct info into the node tree output
Enable/disable subdiv modifier - It should work correctly
Enable GPU subdivision
Enable/disable subdiv modifier - The object created via GN does not care if the original object's modifier is disabled and will always reference it with it enabled
Added subscriber: @Leo-Luther
Added subscribers: @kevindietrich, @iss
This actually is working correctly here until the moment GPU subdivision is enabled. Then it does not work even if it is disabled.
CC @kevindietrich
I'm also running into this issue right now. Looks like the issue is that
me->runtime.mesh_eval
andme->runtime.wrapper_type
are set inmesh_wrapper_ensure_subdivision
, but are never unset when the modifier is disabled or the subdivision level is set to zero.File to reproduce the issue:
subdivision_update_bug.blend
Just disable the Subdivision modifier and see that the other object does not change.
It does work when reloading the file with the modifier being disabled.
A subdivision level of 0 will effectively disable the modifier. I guess a fix could be to unset/delete the runtime subdivision data before executing the modifier stack, if no subsurf modifier is enabled.
Yes that sounds reasonable. Can you look into that?
I can look into it, yes.
Added subscribers: @brecht, @lichtwerk
Caused by
ca9d65cc97
CC @brecht
Geometry nodes: Object info does not care if referenced obejcts subdivision surface modifier is disabledto Regression: Geometry nodes: Object info does not care if referenced obejcts subdivision surface modifier is disabledThis issue was referenced by
0357dbf148
35da733e6b
