OpenCL error when trying to render with Vega 64
Open, Needs Triage by DeveloperPublic
Windows 10 Home, RX Vega 64
2.79b hash: f4dc9f9d68b (newest official)
When trying to render with my gpu (amd Vega 64) I am getting following error: CL_MEM _OBJECT_ALLOCATION_FAILURE in clCreatorBuffer
Just open the file and render using gpu
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.Nov 5 2018, 11:13 AM
Seems like the file is missing?
Sorry - here is the file.
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Nov 11 2018, 10:33 AM
OK, file is here
@Piotr (arcman) Hi, just to be sure that it is not an out of memory issue. can you try to render it with Simplify texture limit set to 1024?
Thanks
This comment was removed by Piotr (arcman).
@Jeroen Bakker (jbakker) With Simplify texture limit set to 1024 the rendering works just fine (in case of this file). In the meantime It appeared that there is a problem with rendering a pocket studio splash (attached). When rendering with simplify texture limit set to 1024 I am getting an error: cl_out_of_resources clenqueuendrangekernel
With simplify turned off I am getting a cl mem object allocation failure in clcreatebuffer error.
@Piotr (arcman) Not expected. Can you add your system info and clinfo to this ticket. Will try to confiscate a Vega64 here and see if I can reproduce the issue.
