moving multiple nodes in node editor
Operating system: Windows 10
Graphics card: GTX 970
Broken:
#1 In the node editor I can't select multiple nodes with shift click.
#2 I can't move multiple nodes in the node editor
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.Dec 3 2018, 2:31 PM
Can confirm this issue.
It's a known issue, also described here: https://developer.blender.org/T57918
I even have a patch to fix it here: https://developer.blender.org/D4055
Jacques Lucke (JacquesLucke) claimed this task.
This seems to be fixed already.
@Jacques Lucke (JacquesLucke) it’s not actually fully fixed. If you select multiple nodes and drag on them, only the one you drag on is moved.
I compared this to Blender 2.79 and it has the same behavior. So I did not consider this to be a bug.
Actually this was the same behavior as on objects in Blender 2.79.
@Jacques Lucke (JacquesLucke) you are right, it’s not really a bug, more a todo
