Cant set particles[0].hair_keys[-1].co = Vector((0,0,3)) #60930
Reference: blender/blender#60930
There is no way in blender 2.8 to write hair_key- [x].co to hair particle system.
Simple blend file with one particle hair and script:
HairKey_Set.blend
Works ok in blender 2.79. I tried to write hair_key.co to depsgraph evaluated object, but it would not work too.
Added subscriber: @JoseConseco
Added subscriber: @YoklJO
I haven't worked on Blender's source before, and found this ticket which seemed debuggable.
I found the culprit, which is in
rna_ParticleHairKey_location_object_info
ofrna_particle.c
.In this check:
if (psmd && psmd->mesh_final && psmd->psys) {
,mesh_final
is null, so it never finds theParticleHairKey
instance to modify. I don't really know what mesh_final is for, but I noticed that it isn't used anywhere in the function, so changing that if statement to:if (psmd && psmd->psys) {
makes the problem in this ticket's description go away. I have no idea if this will cause other problems, because maybe it's important to check thatmesh_final
is not null.Added subscriber: @Jandals
I have run into this same problem writing to hair_key- [x].co and I've also noticed that it's not just the ParticleHairKey that can't be found. When I try to access it, the Particle instance can't be found either.
If I'm looking for
reading from
also fails, which used to work in 2.79.
Added subscriber: @Lichtso
The problem goes far deeper:
Depsgraph copies every object and all their parts including ParticleSystemModifierData.
The copy of ParticleSystemModifierData is used in deformVerts and gets a mesh_final assigned.
However, the rna_ParticleHairKey_location_object_info looks in the original object for the ParticleSystemModifierData and that one never gets a mesh_final.
rna_ParticleHairKey_location_object_info also does a linear search over all hairs for every access to a HairKey which is extremely inefficient.
Thus, rna_ParticleHairKey_location_object_info is fundamentally broken in two ways: Its performance and it can never output a ParticleData pointer.
As the comment in the source code says, a fix would be storing all needed pointers like ParticleSystemModifierData and ParticleData in the ParticleHairKey pointerRNA.
Here an example of how the pointers of copies look like:
Note: The mesh_final is necessary because blender stores all HairKeys relative to their emitter mesh surface if the PSYS_HAIR_DYNAMICS flag is not set. See the use of psys_mat_hair_to_object in rna_ParticleHairKey_location_object_get and rna_ParticleHairKey_location_object_set.
After new depsgraph changes I tried to set particle hair keys co again, and got it working. Sollution:
Then tab into particle editmode, and out. I should update hair position. Not sure if there is better way (without tab)
Does not work for me it seems.
It does not matter how much I switch between object, particle and edit modes.
And others still have the same problem:
https://blender.stackexchange.com/questions/134532/blender-2-8-dynamically-set-particle-locations-via-python
@JoseConseco That seems more like a work-around to the actual problem. If the original problem is still there, then this ticket should not be set to Resolved.
But this seems to work ok. There is other problem preventing writing to hair positions: https://developer.blender.org/T64805.
Try adding cache manualy, then solution mentioned 2 posts above will work.
