Several issues with Blender units and scale #61352
2 Participants
Reference: blender/blender#61352
Coming from a drafting background, Blender has me a bit confused in regards to grid, units, and scale such as:
a) In the attached file, adding an empty-Cube comes in as 2meters wide. Adding a mesh-Cube comes in (correctly I think) as 20cm
Empty.blend
b) Close Blender and reopen the above file:
c) Add a bezier curve to the above file and go to edit mode. The fish-bones are too large.
d) Grid cannot be hidden in Ortho.
e) In terms of UI design, the notion that we have a scale for the grid (overlays menu) that affects the size of new objects and also having a second unit-scale in scene properties is extremely confusing. I am not sure which of the two is intended as the master control for scale (is it the grid scale ?).
Coming from a drafting background scale is important both for export to 3d printers and manufacturing, but also helps the software avoid floating point errors when the models are in millimeters.
Added subscriber: @ThomasAn
Added subscriber: @ZedDB
b) is because the
Add Cube
operator saves the size of the added cube. So when you change the scale, it will still have the previous added cube size saved.But yes, the unit scaling is a known problem and will be tackled later.
d) It was decided to only let the user toggle the grid on and off in perspective view (as the tool tip says):
https://developer.blender.org/D4116
e) the master control right now is the unit scale. The grid scale is only visual.
As you seems to know how you want this to work, and have experience in the area, could you draft up a proposal on how you want this to work over at:
https://blender.community/c/rightclickselect/
All of the things you listed are sadly not bugs but pitfalls that happens because of how all of this was implemented.
It would be awesome to have a nice proposal to go after when we have time to tackle this issue.
Fair enough. Being new to Blender and coming from the outside this is the golden time of opportunity to catch UI rough edges, before I get used to them and start ignoring stuff.
Added the following UI recommendation
Looks good! Be sure to tell your friend and others so it can be up voted!
