Eevee won't render particles #63056
Closed
opened 2019-03-28 16:45:19 +01:00 by Javier Diaz de Leon · 8 comments
Operating systems: Windows 10 Pro, with the latest update as of March 27, 2019. And Linux.
Graphics card: Nvidia GeForce GTX 1060 6Gb. And Nvidia GTX 960.
Blender Versions
Broken: 2.80, Hash: cd92f8ea4326 and 532536bf52, as found on the splash screens.
I initially started this animation in 2.79b.
I am able to see the particles animating in 2.80. And they do render with Cycles.
There are other objects in the scene that do render with Eevee.
I’m using a simple 4 sided object with plain white on it, not UVed, no texture.
With HDRI illumination.
YAFU (https://blenderartists.org/u/YAFU) said this: If Emitter is configured as Wire for Viewport Display in Object tab, particles are not rendered.
Here's his .blend file
Nothing special, just create a particles system and try to render them with Eevee.
**System Information** Operating systems: Windows 10 Pro, with the latest update as of March 27, 2019. And Linux. Graphics card: Nvidia GeForce GTX 1060 6Gb. And Nvidia GTX 960. **Blender Versions** Broken: 2.80, Hash: cd92f8ea4326 and 532536bf52da, as found on the splash screens. **Short description of error** I initially started this animation in 2.79b. I am able to see the particles animating in 2.80. And they do render with Cycles. There are other objects in the scene that do render with Eevee. I’m using a simple 4 sided object with plain white on it, not UVed, no texture. With HDRI illumination. YAFU (https://blenderartists.org/u/YAFU) said this: If Emitter is configured as Wire for Viewport Display in Object tab, particles are not rendered. Here's his .[blend file ](https://blenderartists.org/uploads/default/original/4X/0/9/8/098058b871df1f30733303dd96907705adbeb763.blend) **Exact steps for others to reproduce the error** Nothing special, just create a particles system and try to render them with Eevee.
Added subscriber: @JavierDiazdeLeon
This issue might be related to this one: https://developer.blender.org/T62548
Added subscribers: @fclem, @WilliamReynish
To make the emitter be invisible, go to Properties > Object > Instances > Render Emitter and turn it off.
Then set the Render As setting to Textured.
@fclem It is indeed a little weird/unexpected that the Viewport Display wire & boundbox setting affects the final render. Is this something we should address?
To make the emitter be invisible, go to Properties > Object > Instances > Render Emitter and turn it off. Then set the Render As setting to Textured. @fclem It is indeed a little weird/unexpected that the Viewport Display wire & boundbox setting affects the final render. Is this something we should address?
Clément Foucault was assigned by Sebastian Parborg 2019-03-31 22:07:33 +02:00
Added subscriber: @brecht
Viewport settings should not affect the final render.
Clément Foucault was unassigned by Jeroen Bakker 2019-04-04 14:06:53 +02:00
Jeroen Bakker self-assigned this 2019-04-04 14:06:53 +02:00
Member
Is not EEVEE only issue, workbench does the same. Might be depsgraph issue.
Member
Reference: blender/blender#63056
