Small object are not selected with Box Select tool
Closed, ResolvedPublicBUG
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 388.13
Broken: version: 2.80 (sub 53), branch: blender2.7, commit date: 2019-04-02 19:53, hash: rBa813e259d630
Worked: 2.79 official
Objects that are too small to be visible in the viewport don't get selected with Select Box tool. Other selection tools like Circle Select or Laso Select work as expected. The problem exist in all viewing modes (wireframe, solid, eevee). In Blender 2.79 all objects get selected no matter how small they are.
  1. Open the attached blend file. There are two cubes, one with scale 10, the second with scale 0.01.
  2. Zoom out to see the larger cube.
  3. Select the large cube to make it active.
  4. Box Select both cubes. The small cube does not get selected.
  5. Select the small cube to make it active.
  6. Box Select both cubes. Both cubes get selected.
Related Objects
Brecht Van Lommel (brecht) raised the priority of this task from 50 to High.
Not sure if this is for @Campbell Barton (campbellbarton), @Clément Foucault (fclem) or someone one else. Or if this is some known limitation of new selection code.
This is a limitation in OpenGL Queries (2.7x has this issue too).
Setting as low priority since it's not a regression in occlusion queries.
Possible solutions I can think of aren't especially nice:
  • Draw vertices & edges when selecting (not just the surface geometry).
    While this guarantees correct selection, it's extra drawing to support this corner case.
    Patch for mesh drawing:
    1diff --git a/source/blender/draw/modes/object_mode.c b/source/blender/draw/modes/object_mode.c
    2index ee2c660ca06..9e81ccc6930 100644
    3--- a/source/blender/draw/modes/object_mode.c
    4+++ b/source/blender/draw/modes/object_mode.c
    5@@ -3196,6 +3196,19 @@ static void OBJECT_cache_populate(void *vedata, Object *ob)
    6 }
    7 }
    8 }
    9+
    10+ if (!is_edit_mode && DRW_state_is_select()) {
    11+ if (me->totvert && me->totedge) {
    12+ /* Check edges because we may have already drawn loose verts. */
    13+ GPUBatch *geom = DRW_cache_mesh_all_verts_get(ob);
    14+ DRW_shgroup_call_object_add(sgl->points, geom, ob);
    15+ }
    16+ if (me->totedge && me->totpoly) {
    17+ /* Check totpoly because we may have already drawn loose edges. */
    18+ GPUBatch *geom = DRW_cache_mesh_all_edges_get(ob);
    19+ DRW_shgroup_call_object_add(sgl->wire, geom, ob);
    20+ }
    21+ }
    22 break;
    23 }
    24 case OB_SURF: {
  • Enable 'Center Points' for unselected objects.
  • Detect object bounding boxes that approach 1x px screen-space scale and use a different drawing method when selecting.
Campbell Barton (campbellbarton) lowered the priority of this task from High to Low.
Low priority? Really? This behavior can have severe, sometimes even devastating effects when unnoticed.
When you spend for example significant amount of time cleaning up some complex imported model, miss out on a few small pieces, do not notice and either save file and reopen after or run out of the undo steps, you may end up having wasted up to hours of work.
Agree, this is big bug. Unacceptable for stable release.
Issue came up in T65856 as well, just wanted to note we have T64282, where T64281 (Option to lasso-select using geometry instead of object centers) was added.
So maybe we should add the opposite there as well? [selecting object centers with box select]
Campbell Barton (campbellbarton) raised the priority of this task from Low to Normal.EditedJul 3 2019, 2:00 AM
@Clément Foucault (fclem) mentioned conservative rasterization would solve this, however I could only find a reference to the nvidia extension.
We could enable the extension on nvidia & use a geometry shader for drivers which don't support this, however this adds a performance penalty for all selection, so we'd need to see if it's significant or not.
again another report by me, found ^ this original report this evening now,
as I'm working with blender it IS really an annoying problem which needs to be fixed, and causes serious problems while f.e. grabbing selections
pls close my report as duplicate of this one:
https://developer.blender.org/T69802
Hello, I have to agree with the people above.
This bug results in a lot of mistakes and lost objects.
Really appreciate the work you are doing with the software though!! :)
If we're not likely to get conservative rasterization done for 2.81, a simpler solution could be to use the existing geometry batch to draw wires (even though it's GPU_PRIM_TRIS).
Then at least we wouldn't have to create new batches just to draw edges.
question only: does https://developer.blender.org/project/board/2/ mean this task is not on the 2.82 workboard ?
yep I'm guessing this would resolve the issue, as lassoo and circle select don't suffer from this bug.
Or better still make all of the selection tools consider geometry and centroids. This way you'd be guaranteed selection at any distance regardless of how much of the object falls within the selection perimeter.
This uses existing batches to lines to account for faces being side-on, points to account for edges being viewed side-on.
While I don't like this at all since it's drawing 3x times, it does resolve the issue without using extra GPU memory to store edge/vertex batches.
diff --git a/source/blender/draw/engines/basic/basic_engine.c b/source/blender/draw/engines/basic/basic_engine.c
index 0dd1a4fd686..feaef731d38 100644
--- a/source/blender/draw/engines/basic/basic_engine.c
+++ b/source/blender/draw/engines/basic/basic_engine.c
@@ -189,8 +189,26 @@ static void basic_draw_scene(void *vedata)
   BASIC_PassList *psl = ((BASIC_Data *)vedata)->psl;
-  DRW_draw_pass(psl->depth_pass);
-  DRW_draw_pass(psl->depth_pass_cull);
+  /* Until we have conservative rasterization, this is a hack but it works. */
+  if (DRW_state_is_select()) {
+    glPolygonMode(GL_FRONT_AND_BACK, GL_POINT);
+    DRW_draw_pass(psl->depth_pass);
+    glPolygonMode(GL_FRONT_AND_BACK, GL_LINE);
+    glPolygonMode(GL_FRONT_AND_BACK, GL_FILL);
+    DRW_draw_pass(psl->depth_pass_cull);
+  else {
 static void basic_engine_free(void)
Edit: testing this with high poly scenes and it can be ~80x slower, so it's not practical to use.
Clément Foucault (fclem) changed the subtype of this task from "Report" to "Bug".Jan 29 2020, 12:54 PM
+  else {
This mainly concerns object mode, not edit mode (I never encountered this issue in edit mode), so why take topology in consideration at all for tiny objects? Testing bounding boxes/origins for objects below certain screen size (determined by bounds) should be enough...?
Clément Foucault (fclem) closed this task as Resolved.Feb 4 2020, 3:33 PM
Hey everyone,
Quick workaround - Use Toggle X-Ray (Alt+Z /Option+Z) when you're in a pinch. This is so far working flawlessly for me in 3.2.
Rudimentary guess, when a selection is made in face mode, ngons that take up less than n% of the viewport in screen space aren't being considered? That's why it works in X-Ray, faces seem to be selected by their central points instead of by merit of their area in relation to screen space.
I hope this helps...
Good luck!
