Enabling "Steroscopy" in the viewport camera causes graphical glitches with anti-aliasing enabled. #76874
8 Participants
Reference: blender/blender#76874
System Information:
Operating system: Linux-5.4.0-7626-generic-x86_64-with-debian-bullseye-sid 64 Bits
Graphics card: GeForce GTX 1050 Ti 440.82
Blender Version:
Broken: 2.83
ff7a30d92884
(2020-05-18 23:31), 2.907bd07c9f5adf
(2020-05-18 23:33)Worked: 2.82a
Short description of error:
This isn't a new issue, it just seems it was missed during
365e9cb6aa
. This task was created as an extension of #74243 because #74243 was closed.Edit: This may also be related:
5593efec01
Exact steps for others to reproduce the error:
Note 1: This issue only occurs in solid mode. The issue also seems to disappear if you change to "Material Preview" or "EEVEE rendered" mode at anytime while having that Blender instance open. E.G. Open Blender, switch to "Material Preview" mode, switch back to "Solid" mode then enable "Stereoscopy" and go the the active camera. Now the issue won't occur. Load factory defaults, enable "Stereoscopy", switch to active camera, the issue won't occur. I have to close Blender and re-open it to get the issue to occur again.
Note 2: I have tested to ensure the issue described in #74243 hasn't returned. So far I'm only seeing the issue with stereoscopy. The issues with weight paint and wireframes hasn't returned as far as I can tell.
Workaround:
Change shading to material mode once and the issue is gone.
Added subscriber: @Alaska
#83873 was marked as duplicate of this issue
#79351 was marked as duplicate of this issue
Removed subscriber: @Alaska
@fclem I have assigned you to this task as you worked on the fix for the other issue. Sorry if this task should be assigned to someone else.
Added subscriber: @Blendify
I cannot reproduce on windows.
Looks like it may end up like #74243. A Nvidia only, Linux only issue. Will need more investigation to confirm this.
Added subscriber: @lichtwerk
I can confirm actually
Operating system: Linux-5.5.13-200.fc31.x86_64-x86_64-with-fedora-31-Thirty_One 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.64
version: 2.90 (sub 2), branch: master, commit date: 2020-05-19 03:31, hash:
1151bcd53d
Added subscribers: @Jeroen-Bakker, @dfelinto
@fclem @Jeroen-Bakker I can reproduce this on Linux btw using
GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.44
.@Alaska for the record, refrain from tagging your own report as 2.83. The tag means the issue is planned to be tackled by 2.83, not that it happens in 2.83. But for now leave it as it is, since I hope this can be fixed for 2.83.
I will keep that in mind for future reports.
@fclem: Probably again something along the lines of the following?
P1403: T76874_snippet
Added subscriber: @ZsoltStefan
I can confirm this also happens on Windows. I get a red/cyan checkerboard pattern in the upper part of the screen. If there are more 3D views open, and one is in camera view, then the other viewports also get the glitch even if they are not in camera view. Switching to Material Preview and back to solid shading solves the problem.
Graphics card: GeForce RTX 2080 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.90 (sub 2), branch: master, commit date: 2020-05-18 09:05, hash:
f3edff2d7d
Removing the Linux project as @ZsoltStefan can reproduce the issue on Windows.
I am also able to reproduce the issue where other viewports get corrupted when one is in the camera view.
In the end this is a driver issue. And with a workaround (change once to material mode, and the issue is gone once you go back to solid). Moving this to known issue.
Added subscriber: @fclem
Added subscriber: @Rogo
Added subscriber: @sundriftproductions
Removed subscriber: @Blendify
Added subscriber: @pmoursnv
This has been fixed with the r460 driver releases (Windows 460.79+, Linux 460.27.04+). Please try again and let me know if it can be closed.
@pmoursnv -- I installed driver version 460.89 for RTX/Quatro on Windows (https://www.nvidia.com/Download/driverResults.aspx/167756/en-us ) and the problem appears to have been fixed with this driver version.
I don't know if the problem is also resolved on Linux systems.
I just thought I would update on this since it's been a while. I am still able to produce this bug, or something similar, with the setup below:
Operating system: Linux-5.15.0-1-amd64-x86_64-with-glibc2.32 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 495.44
Blender Version 3.1.0
The problem is also still here on:
Operating system: Linux-5.11.0-40-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.91.03
Turns out this was accidentally only fixed on Windows, not Linux. I'll bring it up internally.
Linux Nvidia GPU driver 510.47.03 has this in the changelog:
And updating to GPU driver 510.47.03 does indeed fix the issue for me. As such I will be closing this report.
