Some hair particles are rendered the wrong material in EEVEE #78845
9 Participants
Reference: blender/blender#78845
Operating system: Windows 10
Graphics card: GTX 1060 6GB
Broken: 2.90,
ee5c2f6ead
, master, 2020-07-11Worked: 2.83.2
Caused by
b18c2a3c41
there are 3 planes, each plane has two particle hair systems. the particle hairs that on the same plane has the same material.
in blender 2.83 LTS. the color display as intended. since 2.90, when both hair system are active, the color is mix with others of different planes and different materials. if either one of the hair systems that on the same plane is disable, the color return to normal. in 2.83 it looks right, but in 2.90 and above, the blue and green materials also mix with red somehow.
open attached blend file in 290 and above, switch to preview render to see the color mixed within different materials.
change the color_ramp.interpolation to different type from each other would fix the issue, for example, mat1's color_ramp.interpolation to linear, mat2's color_ramp.interpolation to ease, mat3's color_ramp.interpolation to cardinal
particle hair color.blend
Some of the hair particles (the right eyebrow specifically) in the provided file are shaded with other material, unless some of the other objects are hidden (the left eyebrow or both eyelashes)**
Note that this is not the same issue as described in this issue , the provided file used to work on older blender versions and the scale of the objects is always positive.
hair_material_bug.blend
Added subscriber: @tiagomeraki
#87379 was marked as duplicate of this issue
#85973 was marked as duplicate of this issue
Added subscriber: @mano-wii
You forgot to attach or pack the
texture.So when we open the file we don't see any particles.
But after I deleted the texture I could see the problem.
Here the simplified file:
I will edit the description.
Some hair particles are rendered as black unless some objects are hidden from viewport in EEVEEto Some hair particles are rendered the wrong material in EEVEEMy bad, I was pretty sure I had packed this texture into the .blend. Thanks for taking the time and fixing the file. Next time I'll make sure to test it at another path before submitting the bug report, and take more time getting it to a minimal state and easy to test with as you did.
Added subscriber: @nimajneb7
I've been having this issue as well.
If two hair systems use materials with the same node layout, they will render the with same material, even if the two materials have different values or textures.
Added subscriber: @agorka
I'm having this problem too, tested in 2.90.1, 2.91 and 2.92.0 Alpha
Uploading another example. Hiding red eyebrows makes upper eyelash render correctly in black. Bug happens only in eevee renders, cycles handles this correctly.
Also, duplicating eyebrows and changing hair material of one of them to black changes lower eyelash color to red.
Something really weird happens there.
Head0002_hairmaterialbug.blend
Added subscriber: @Keeya
I have encountered this bug with multiple objects that use multiple hair particle systems and materials. If your object has multiple material slots which the particle systems use, it goes haywire.
I have this test case:
I can't really seem to find a pattern to what is happening but I feel the material slot given in the particle system render options is not referencing the thing the UI shows as if it goes out of sync with the UI.
Also if you move the material slot (change top <-> bottom), the referenced one in the particle system->render tab also swaps which I feel should not.
Edit: it specifically happens if you have an object with multiple particle systems that use the same material. I have used that for different type of fur layers.
Possible workaround: You can kinda workaround it, if you create a separate material, duplicating it, for each particle system.
blender 2.91.0
blender-hair-particles-material.blend
Added subscriber: @SachaGoedegebure
Added subscriber: @sid350
Added subscriber: @lichtwerk
Will set to high prio since it is a regression, we have the culprit commit and has been reported again in #87379
Added subscriber: @sleepyhead
This issue was referenced by
2f6219c48d
