Cycles CPU Preview Artifact #80736
6 Participants
Reference: blender/blender#80736
Operating system: Xubuntu 19.10
Graphics card: GeForce RTX 2070 SUPER
Broken: 2.90.0, branch: master, 2.91.0 alpha
Worked: 2.83.5
Posing the rig with Rendered Display Viewport Shading causes artifacts to appear.
Load attached file
Switch to Rendered Display preview mode.
Grab/move the T_Arm.L target bone.
Switch to any other Viewport Shading mode.
Switch back to Rendered Display.
The meshes will be correctly displayed.
Other:
There is a hexagonal ngon in Mech_Arm.L. Delete it, and the artifacts go away.
(I applied Grid Fill to the ngon as a test, but no change)
I've simplified the rig considerably to isolate a possible cause.
In the full rig, the artifacts appear all over: arms, legs, torso, head.
Full render is not apparently affected (only preview).
B290_cycles_preview_artifact.blend
system-info.txt
Added subscriber: @Cyclotron
Added subscriber: @NRH_BEATS
435.21 very outdated driver, this branch not supported anymore.
Install xUbuntu 20.04.1 LTS with perfect and latest 450.66 driver out of box.
https://xubuntu.org/download
Added subscriber: @iss
There is corrupted mesh
ID3220
but that doesn't seem to be cause of this issueAdded subscriber: @Alaska
@iss I am able to reproduce a bug like this in different scenarios, here are the steps for reproducing. I should note that the issue seems to show up in different places when comparing Blender 2.90.1 and 2.91. I have marked each guide with the versions it shows up in.
System Information:
CPU: Ryzen 9 3900X
Graphics card: RTX 2060 SUPER 456.38
It should be noted that on Linux I can only reproduce test 3 based on testing so far.
Linux Kernal version: Linux-5.8.0-2-amd64-x86_64-with-debian-bullseye
Blender Version:
Broken: version: Tested 2.90.1 and 2.91.0 Alpha
7ab8d7c939
(2020-10-09 21:39)Exact steps to reproduce (Test 1 - Reproducible in Blender 2.90.1 and 2.91):
and set the rendering device toCPU
.Particle System
set to typeHair
.sub-division surface
modifier.sub-division surface
modifier. Now the cube should have some artifacting or missing geometry (depends onsub-division
level).Exact steps to reproduce (Test 2 - Reproducible in Blender 2.91):
.Particle System
set to typeHair
modifier with theViewport level
set to 4.sub-division surface
modifier.Exact steps to reproduce (Test 3 - Reproducible in Blender 2.90.1 and 2.91):
Owl.arm
and move it around. You should notice artifacts on the owl mesh.#80736 - Owl.blend
It should be noted that in all these tests doing at least one of these things seems to resolve the issue and stop it from re-occuring:
GPU
fixes the issue (suggests it might be caused by Embree).Viewport BVH type
toStatic
also seems to solve the issue (Probably narrows it down to Embree's BVH refitting).Added subscriber: @EAW
That owl’s corruption looks similar to my Suzanne’s in #81587.
I took a look at your file in that task and played around. Crashing is less frequent on my CPU (Ryzen 9 3900X), however in many cases I'll end up in situations like the "corruption" you've shown in your Suzanne and I've shown in the owl.
Note: I am unable to reproduce crashing in your task (#81587) on Linux (based on testing so far).
Also, while playing around with the owl scene, your Suzanne, my hair scene, I see common crashes like in this report #81102. Might be related?
#81102 is very similar. My crash log used to be almost identical, but there was a commit in the last two or three days that caused some of the TBB calls to change. Thanks for looking into mine and letting me know about #81102 @Alaska!
Added subscriber: @brecht
FYI @Alaska ,@iss, and @brecht,
Test 1 & Test 2 from @Alaska's comment have been fixed by
6d8e03ddd9
.Test 3 is not fixed.
Tested using
e4728d0a16
as a control, All three tests produced the artifacts.Tested using
390b28e338
, with the fix, only Test 3 showed artifacts.Operating system: Windows-10-10.0.18362-SP0 64 Bits
Graphics card: GeForce GTX 470/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
I can't reproduce the issue with Test 3. Does it happen reliably or randomly?
I also can't reproduce issues with test 3. I rendered on CPU with openCL
Graphics card: Radeon RX550/550 Series ATI Technologies Inc. 4.5.14736 Core Profile Context 20.8.3 27.20.12027.1001
I am also unable to reproduce the issue with Blender 2.92.0 Alpha
7872bcafa0
(2020-11-02 14:36)I am also unable to reproduce the artifacts shown in the original report for this task (#80736).
Maybe it's an issue with older CPUs? as @EAW does have an older Intel CPU. Note sure.
Changed status from 'Confirmed' to: 'Needs User Info'
I doubt this is related to CPU architecture. Maybe @EAW made a mistake in testing?
Reran test 3 with:
version: 2.92.0 Alpha, branch: master, commit date: 2020-11-04 17:16, hash:
331614e09b
, type: Releasebuild date: 2020-11-04, 17:45:49
platform: Windows
The issue is gone @brecht .
Changed status from 'Needs User Info' to: 'Resolved'
Ok, great.
Added subscriber: @howardt
Out of curiosity, I git bisected the commit that fixed Test 3.
Fix Cycles unnecessary overhead cancelling finished task pool
