Blender 2.9 external renderer shader node bug #80780
5 Participants
Reference: blender/blender#80780
Operating system: windows 10 64 bit
Graphics card: RTX 2060 super
Broken: Blender 2.90 official / but it happen since a while now with older blender version
Worked: reported once here : https://developer.blender.org/T76381
Blender doesn't save animation keyframe input (color/Value ...) in shader node with luxcore render engine.
From the blendluxcore Devs it is a blender issue.
1/ install luxcore render engine from here : https://luxcorerender.org/download/
2/ in blender switch to Luxcore engine
3/ add a shader matte (or any shader)
4/ animate any shader value of your choice.
Added subscriber: @sharlybg
Blender 2.8 external renderer shader node bugto Blender 2.9 external renderer shader node bugAdded subscriber: @juang3d
This is kind of super important for any third party render engine
Added subscriber: @iss
I can confirm, that preview is not updated when scrubbing timeline, Render is updated.
@sharlybg do you have link to ticket in luxcore bugtracker?
As it is a blender bug i didn't open a bug issue on Luxcore bug tracker. But just in cases it is needed here is the link to the BlendLuxcore bug tracker : blendluxcore bug tracker
Changed status from 'Confirmed' to: 'Needs User Info'
You said "From the blendluxcore Devs it is a blender issue." So I assumed you reported this and they said it's bug in Blender, I also confirmed this on that basis. It would definitely help if we knew why this is bugh in Blender.
Since I have not triaged this really, we need to have another look. But to triage this issue we need example file that demonstrates the bug. I would assume that the node or tree is not doing something sometimes, but I need to know that exactly. Having example file is best because both of us can test if things are working correctly.
Sorry if I misunderstand something.
Sorry for late reply. Here is the file :
Test blend.blend
Tried the file in Blender 2.83LTS + Blendluxcore 2.4 official and it work. But Blender 2.83LTS + Blendluxcore 2.5 don't.
will test blender 2.9 official + 2.5 and 2.4 blendluxcore.
Thanks for example file, but that is not quite what I meant. This would require us to work not only with Blendr code, but also with Luxcore's. We should not need to use Luxcore to demonstrate this bug if it is bug in Blender.
Tested with Blender 2.9 + Blendluxcore 2.4 and it work.
Added subscriber: @BYOB
@BYOB Hi, I don't know if you know about this issue, but since you are Luxcore dev can you share some information that can help us track and fix this?
With Blender 2.9 and latest BlendLuxCore v2.5 I can not reproduce the problem.
Blender 2.9 and latest BlendLuxCore v2.5 same issue with two files :
Test blend.blend
XX0001-0100.avi
and this one
0001-0070.avi
#76381.blend
You should include a description what the actual bug is.
I thought the problem was that keyframes can't be set on properties of custom nodes, or don't show up in the UI.
However, the actual problem is that keyframes on custom node properties are either not evaluated or not updated when doing a final render of the full animation with Ctrl+F12. Rendering individual frames with F12 works as expected, and the keyframes show up in the UI as yellow/green on the node properties.
I can reproduce the issue with Blender 2.9 and BlendLuxCore v2.5 (have not tested other versions of either).
I have put together a minimal script to show the issue without requiring the installation of the BlendLuxCore addon:
custom_node_props_test.zip
So, in a
frame_change_post
handler, the custom property is animated correctly, but during final render animation it is not updated.Any update about this issue fix ?
@BYOB Thanks a lot for minimal example file. I checked this in 2.90 and I can confirm this issue, but I can't reproduce in latest 2.91.
@sharlybg can you download latest development build from https://builder.blender.org/download/ and check if problem is still there?
Added subscriber: @ankitm
Any update here, @sharlybg ?
Lastest 2.91 and luxcore give black screen in render viewport so it is impossible to test.
Official 2.90.1 and blendluxcore 2.4 Work :
2.4.avi
Official 2.90.1 and blendluxcore 2.5 Don't Work in Final render : But strangelly work in viewport.
2.5.avi
Is it the same bug as #71908 (Keyframed parameters are not preserved when frame_change_post handler is used) ?
I with provided example script I still have no issues in 2.91. Also if the issue truly boils down to what is in provided example file, then it is not the same issue as #71908.
Since I can reproduce issue in 2.90 and not in 2.91 I will close this report now. If this bug can be reproduced in 2.91 please comment here or open new report.
