Geometry Nodes seems to ignore the (last) Subdivision modifier on the stack #97221
Reference: blender/blender#97221
Operating system: Linux-5.4.0-107-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.54
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Worked: 3.0.1
Geometry Nodes seems to ignore a Subdivision modifier (on a referenced Object (Object Info Node, Collection Info Node)) if it is the last modifier on the stack. If another modifier is added behind it, everything seems to work just fine.
It seems to be OK if I activate "As Instance" on the Object Info Node. But adding a Realize Instances Node afterwards leads to the same issue again.
1.) Add a Subdivision Modifier to the Default Cube.
2.) Add a second Mesh Object to the scene.
3.) Add a Geometry Nodes Modifier to the second object.
4.) Add an Object Info Node (referencing the Default Cube) to the node tree.
5.) Connect the Object Info Node's Geometry output to the Group Output
The Output Geometry is unsubdivided in Blender 3.1 and 3.2 but subdivided in 3.0.GN_Subdivision_Demo.blend
Added subscriber: @Helge-4
Added subscriber: @ab_stanton
Does this stop happening if you disable GPU subdivision? If so then I assume it's related to https://developer.blender.org/T96729 ?
Will close this as duplicate of #95700 (GPU subdivision: Referencing object with subdivision surface with Object info node does not work)
Disable GPU subdivision as a workaround: {nav Edit > Preferences > Viewport > Subdivision > GPU Subdivision}
Thanks for reporting :)
Closed as duplicate of #95700
You are right, it seems to be the same underlying issue. I never would have guessed. Thanks for pointing me in that direction.
Thanks, that makes sense. As this only happens for the last modifier on the stack, maybe I'll find a lightweight modifier (like Mirror with all axis deactivated) which I can use as a 'dummy last modifier'. This way I should be able to keep GPU Subdiv active in viewport but the non GPU version for Geometry Nodes.
