Gravity ignores units scale #52238
8 Participants
Reference: blender/blender#52238
Ubuntu 16.10, GeForce GTX 950M/PCIe/SSE2
Broken: 2.77a
When dropping an object from 20m high, it takes about 2 seconds before it hits the ground. At 60fps this is sqrt(20*2/9.81)*60=121.16 frames. As it starts falling at frame 1, it should hit the ground around frame 122. Blender does this correctly.
Now if the scale is set to 0.1, that 20m becomes 2m. Dropping an object from 2m high should take sqrt(20*2/9.81)*60=38.3 frames. Hence the object should hit the ground at frame 39. However, it doesn't and still hits the ground at frame 122.
gravity.blend
Open the file gravity.blend
Press N and select the pole to see that it is 20m high, indicating that the bottom of the cube is 20m above ground.
Click play animation (alt+a)
When the cube hits the ground pause the animation (alt+a)
Compare frames 121 and 122 and note that it correctly hits the ground at frame 122.
In the 'properties' area under the 'scene' tab in the 'units' section, set 'scale' to 0.1.
Note that the pole's hight now has changed to 2m.
Note that the gravity is still shown as -9.81m/s².
Rewind the animation and play again.
Note that the cube still hits the ground at frame 122, instead of the expected frame 39.
Workaround
Related bugs
#27311 Maximum value of physics gravity is too small
#40925 Scene gravity hard limited
Added subscriber: @bcmpinc
Added subscriber: @SteffenD
Added subscriber: @ThomasSeidelmann
Can confirm, also related to and mentioned in #49544.
It does not just affect rigid body physics, but also cloth simulation (see the given task for an example), as well as several other things. The issue is simply that certain subsystems of blender ignore the unit scale, while others do not. A mismatch basically.
Removed subscriber: @ThomasSeidelmann
Added subscriber: @LazyDodo
Can confirm the behavior, however, it's working as designed, and even if we were to go out and change this behavior it's not and easy fix and it is likely that the physics will get some rework in 2.8 anyhow, so I'm gonna have to classify it as a feature request and close it, we'll revisit once the physics code in 2.8 gets some love.
Added subscriber: @Stewie
is this solved in 2.8?
Added subscriber: @dark999
@Stewie you can check it youself, just dowbload Blender 2.80 Stable from here
No, this is still an issue in 2.80.
As mentioned by @LazyDodo, this is working as designed currently. The unit scale only affects the UI. We might change this at some point, but for now this is not a bug.
Then it's still a UI bug. Because if the unit scale only affects the UI, then changing it should affect how the gravity is displayed in the UI.
So in the reproduction steps, where it says:
The expected result should be:
This should be easy to fix.
Once the user changes the -0.981 back into -9.81m/s² they should see the expected result.
Closed as duplicate of #61313
Added subscriber: @int-ua
